Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 10:34 PM
96f150beater 96f150beater is offline
96f150beater is starting off with a positive reputation.
Angry 96 f150 fires sometimes, sometimes it wont
i have a 96 ford f150 short cab 5.0 dual tanks, first it had an engine light on which was the crank shaft position censor, fixed it, still it just turned over and didnt start, changed cap and rotor it fired up, few days later didnt want to start, changed plugs, wires, coil, even after that i still have the same problem, my buddy did a fuel pressure test and the front tank was bad back tank was good, he says run it off the back tank, i did that, same problem, cranks but will not start, so i changed the fuel filter and fuel pump on the front tank, still am having a problem, it will fire sometimes but not all the time and when it does, it runs really good, i do not know what else to do, should i have changed the rear fuel pump also??? anybody have any suggestions?
  #2 (permalink)
Old 11-04-2009, 03:33 PM
george6488 george6488 is offline
george6488 is starting off with a positive reputation.
I'd suggest you post in another forum as this one is for 2009 & 2010 F-150
  #3 (permalink)
Old 11-04-2009, 03:38 PM
DLP Performance DLP Performance is offline
DLP Performance is starting off with a positive reputation.
You need to find out if it's fuel or fire first. Then go from there. Your truck doesn't have a crank sensor.
Tags
150 , 96 , cranks , fires , ford , performance , start , truck , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
