No power at trailer plug in.
My older brother runs his own contracting company, and primarily uses his 05 F250 to pull his 25 foot enclosed trailer around along with skid loaders etc. The interior lighting for the trailer is run using the constant 12v power terminal of the 7 pin RV plug that his truck came with. This terminal has no power switched or constant. All the fuses are good, and the connector itself is in good shape, I also chased the wire back to the cab and it was fine. Looking over the wiring diagram in his chilton its 12v source is a trailer/tow relay, I am unable, however, to locate this relay in either fuse panel. Using the diagrams in the chilton and the owners manual proved useless, also switching the horn relay with all the others did not fix it or locate any bad relays. Anyone have any ideas what the heck is going on?
inside the cab.
107 20A** Trailer tow battery charge
301 Full ISO relay Trailer tow battery charge
I don't see any labeling for the fuse to control the relay itself, but there must be one.. anyhow with the key on, there should be power at 2 of the relay terminals.. power off, only one.
sam
KCBS Smoker
1999 to 2016 Super Duty
13
01-09-2019 02:50 PM
thordehr
Electrical Systems/Wiring
23
05-28-2017 08:19 AM
snaponprofile
06-01-2013 07:49 PM
