Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 06:58 PM
whiteexc22 whiteexc22 is offline
whiteexc22 is starting off with a positive reputation.
Unhappy v10 excursion problems
hey guys i need some help in a bad way...my excursion had been to 4 shops and has been sitting for 7 months now...when you drive the thing and pull up to a stop light or a stop sign and prepare to stop and when you do stop the motor lugs down to around 400 rpm and wants to stall and sometimes does and when you pull away it shifts down to first,so its like it stays in second while your on the break and when you let off the brake pedal and start to roll it shifts down...it also at an idle in park stalls and misses every once in a while...sounds like a machine gun sound at an idle....iac has been changed,,,maf has been changed,,,cops have been changed,,,,speed sensors have been changed.....check engine light is on but registering no codes? tranny shop ran the tranny for codes but came up with nothing....im at wits end trying to fig this out...could it be the main computer? i dunno whats left so hopefully someone out here can help
  #2 (permalink)
Old 11-03-2009, 09:45 PM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
How's the pressure in your fuel rail? And what happens if you shift to neutral when you're at 400 rpm? Check your air horn for a rat's nest....
__________________
2005 F350 V10 6spd dually, 15K receiver. No 4WD, no LS, no A/C, no special cab - just a lean mean towing machine!
Tags
excursion , ford , forum , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
