I had a buddy of mine just use a sheet of treated plywood. we stained it a dark red and cleared it then bolted bed strippes over top without cutting it into planks. It actually came out really good it just takes some time finding the right place to drill for your strippes.
When I was in high school, back when a nice 54 F100 could be had for under $400, my buddy bartered a 54 F-100 from a farmer he worked for during the summers. Someone had poured about 2 inches on concrete in the bed. Made it ride nice but cut into the acceleration. We busted it out and the underlying wood was not that bad. I think he did throw a sheet of marine grade plywood in there to keep the empties from falling out.
I bought my 55 soon after that (for $200) and we had more fun tearing around in those old trucks.
As some of the others on here have done, I used the floor skin from a pickup to redo the floor inside my panel. I welded mine in. I just replaced the plywood floor of my utility trailer as well but bolted it in for this application.
I used Trex in my '54, it's tough stuff and is even the right width. (Specifically the Trex Brasilia stuff the company made some very bad batches of - but they were very generous with replacing it, so now I have LOTS of it!)
It ain't pretty, but neither is the black primer "paint job", so it all works out just fine...
This is something I've been toying with, Lpe wood or in other words Brazilian walnut. This wood has no knots and very dense. I've used it a number of times when I use to design decks. Very low maintained and 30yr. rot life.
Yep, Lpe wood is a term I've been hearing a lot at the Woodie shows I've been going to. And for a Woodie not only does it have to with stand the elements it also has to be structly strong.
__________________
Badges....badges...we don't need no stink'n badges.
Check my gallery , I used synthetic redwood , also heavier for better traction , wont fade and waterproof , $150 plus hardware at home depot , just a thought but I get a lot of compliments .
Haven't seen the "synthetic redwood". Is that the same as the Trex-type decking?
__________________
64 Ford F100 Styleside Short Bed /223 "6" & 4 speed "Little Red"
63 Ford F100 Unibody Styleside Longbed w/292 V-8, 3 deuces, dual exhausts & 3 speed "Big Red"
63 Ford F250 Flareside Long Bed w/292 V-8, two barrel, dual exhausts & 4 speed "Big Un"
63 F100 "Stageway" Crew Cab Long (wrong) bed. 292 V-8 & 3 speed
I just talked to a freelance carpenter I use for odd jobs. I asked him about the possibility of using some type of wood other than Red Oak for a bed floor. He suggested Ipe, said that is what "everyone" is using these days (not sure what that meant). We have it for our back deck and it is indeed some durable stuff. Looks pretty good too, and you can stain it with oil to make it darker. No need for any coating.
I also considered Teak, as our outdoor furniture is made from this, but he thought this would be mighty expensive.
The only issue is that Ipe is generally sold for decking, and thus in planks that measure 5.5" wide by 1.25" thick. I believe the stock bed planks are closer to 6.25" wide by 0.75" thick but mine are so rotted it is tough to measure them. Does anyone know the dimensions?
