1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Questions about 61-63 trucks
Old 10-13-2011, 11:20 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
I don't think ya need 25+ post to post pics. Try this.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
  #32
Old 10-13-2011, 05:46 PM
Scout Pilot's Avatar
Scout Pilot
Scout Pilot is offline
Thanks Buzz.
  #33
Old 04-08-2014, 10:40 PM
averyjones2k's Avatar
averyjones2k
averyjones2k is offline
power steering conversion
i have a 61 unibody and i am trying to convert it to power steering. any sugestions? i have a steering box from a 84 or 85 toyota 4x4 that is suposed to be a perfect fit but it doesn't look like it will work even with a custom bracket. Any ideas or tricks out there to make this work?
  #34
Old 04-09-2014, 02:10 AM
Bill W's Avatar
Bill W
Bill W is offline
maybe you don't have the right box... the info i have read says 79 to "early" 84 box and i would take that to believe toyota changed the steering box sometime in 84 compare the photo in this article to your PS box.
Toyota Steering Box Swap For 1948-1960 Trucks | Ford Trucks
  #35
Old 04-09-2014, 10:55 AM
arctic y block
So Ivel? Did ya give up on your Uni build? Check out mine in my albums for some Ideas.
If your still around.
  #36
Old 08-20-2014, 11:32 PM
RetSgtMaj's Avatar
RetSgtMaj
RetSgtMaj is offline
got a 61 uni long bed project going . The rear wheel wells have been cut out to the larger detail. How do I fix that? Cant seem to find replacement panels for the rear fender
  #37
Old 08-21-2014, 07:52 AM
37 Ford guy's Avatar
37 Ford guy
37 Ford guy is offline
Is that a black truck that was on LAcraigslist for a while? You'll probably have to find a donor uni that is beyond repair and salvage the rear wheel wells to weld into yours.
  #38
Old 08-21-2014, 06:40 PM
91BroncoToy's Avatar
91BroncoToy
91BroncoToy is offline
I was lucky enough to find a Unibody that was cut and turned into a trailer. I'll use the wheel wells and part of the bed floor when I put the narrowed rear end under mine. There are a number of Unibodies around in fields, you just gotta keep an eye out for them. You should post a picture of what you're looking for.
  #39
Old 08-22-2014, 07:52 AM
RetSgtMaj's Avatar
RetSgtMaj
61 uni
Got my 61 from second owner for 500 who had it since the 60s got a fair amount of rust but I am dedicated to bringing her back to life it's a 292 auto and runs great
  #40
Old 08-24-2014, 03:21 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Cant seem to find replacement panels for the rear fender.
Only Flaresides have rear fenders, Stylesides have quarter panels.
1961/63 Uni Styleside:
  #41
Old 09-16-2014, 06:26 PM
61FordUni's Avatar
61FordUni
61FordUni is offline
Very interesting. Ive learned a lot. Im still new to the Uni world, but making progress. Before I do anymore, Im a reader. Read Read Read. There is so much to learn. Right now I'm looking for a guy to help me install a crown vic front clip. I really want P/S. Disc breaks. And a lower ride height.
Any updates?
  #42
Old 09-17-2014, 03:29 PM
Ponchopete's Avatar
Ponchopete
Ponchopete is offline
Dropped axel
I just picked up a 62 all original yet. I am going to just do the Sids dropped axel. Still costing me close to 600 with shipping!
  #43
Old 09-17-2014, 03:32 PM
Ponchopete's Avatar
Ponchopete
Disc brakes
There is a disc brake set up speedway offers,(279.00) and a lot of other shops make them too.
  #44
Old 09-29-2014, 10:40 PM
hottpepper's Avatar
hottpepper
hottpepper is offline
power steering
Just curious, did you figure out this p/s swap? I am just beginning to hope to do the same thing…any advice?
  #45
Old 05-28-2015, 02:03 PM
shustring's Avatar
shustring
shustring is offline
62 Uni
Just picked up a 1962 SWB Uni. Going to start on a wiring harness first since the previous owner wrapped the fuses in tinfoil to keep them from blowing. I looked up the wiring diagram but cant find the wire sizes. Any ideas where I might be able to look? Thanks in advance.
Quick Reply: Questions about 61-63 trucks
