Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
my 84 bronco (pics)
Old 02-26-2012, 07:28 AM
88dually's Avatar
88dually
88dually is offline
any updates ?
  #32
Old 02-27-2012, 11:18 PM
muscletruck7379's Avatar
muscletruck7379
muscletruck7379 is offline
unfortunately not much, other than sanding on some panels and discovering that all the body mounts are shot (which is why the couple of times i have tried bolting the panels on that they wouldn't fit right, look at the pic with the red clip on it while still outside, and look at the gap on the pass side)
about a month ago i got a job in colorado, so I am about 150 miles away from it, and i don't have a chance to go up and work more on it until next weekend, but when i do I intend to either get it fired up, or get the body mounts under it.
  #33
Old 02-28-2012, 04:53 AM
88dually's Avatar
88dually
88dually is offline
Keep up the good work
  #34
Old 06-03-2012, 02:23 AM
muscletruck7379
not much to update, the shop got overridden with pigeons, so i spent most of last weekend getting rid of them, and then using a half a bottle of simple green to get all their... droppings cleaned up.
i did however get my dual range pulled out of the parts truck, needs a little clean up still, but here you go:
  #35
Old 08-01-2012, 11:30 PM
Andrew James's Avatar
Andrew James
Andrew James is offline
Updates???
  #36
Old 08-02-2012, 12:20 AM
muscletruck7379
not really unfortunatly, after moving its 150 miles away and I can only get to it every now and then, i last worked on it about 2 weeks ago, but it was all cleaning and pulling seats and carpet to get to the body bolts as part of replacing the body mounts.
Really wish i could find a cheap garage space to rent around here... although I do assure you that i am not giving up, not by a long shot!
  #37
Old 02-05-2013, 10:00 AM
jthorngate3's Avatar
jthorngate3
jthorngate3 is offline
This is a really awesome project! Just came across it from the link in your sig on the CO thread. A lot of the things you did were things I had thought about, but knew I was not really capable of myself. Can't wait to see you driving that thing.
  #38
Old 03-03-2013, 09:37 AM
smill24v's Avatar
smill24v
smill24v is offline
wow everything looks good man keep it up!
  #39
Old 04-10-2014, 01:21 AM
muscletruck7379
Wow, haven't updated this in a while, but then again I have only been able to work on it sporadically.
I got the body mounts under it over the summer, and finally my fenders will fit without 1" gaps! and talk about a pain to replace...
finally bolted in the starter and exhaust (all two feet of it) I'm hoping that the engine doesn't rock enough for it to make contact with the frame.
I'm also at a bit of a dilemma, and I cant decide where i should mount the connector for the megasquirts harness to pass through the firewall, its a connector built for going through firewalls, and it uses weather-pack terminals, and will require cutting a 2" hole.
here are some of the locations I have been considering:
right now i'm thinking more along the lines of #3, it'll be convenient to wire on the engine side, but up high enough to stay out of dirt /water, and be aesthetically pleasing. provided that it will work on the other side of the firewall as well.
I have been thinking I'll mount the megasquirt in the dash fairly high, and run a custom "DLC" connector for tuning.
any better ideas?
  #40
Old 04-10-2014, 01:23 AM
muscletruck7379
oh and as far as the carb goes, I am planning on using it to get a baseline so i can compare the megasquirt to it later.
  #41
Old 04-29-2014, 06:34 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Rusty_Old_F250 is offline
What brand is the dual range box? Is it an over or an under?
Sam
  #42
Old 05-05-2014, 10:48 PM
muscletruck7379
it was made by US Gear, and from what I understand was part of doug nash.
I'm 95% sure this one is an under/direct. but they could be had in any combination.
buckshot1822
18
03-21-2017 07:55 AM
BioBurner
1999 to 2016 Super Duty
49
12-12-2016 01:57 PM
RAY1986F150
13
09-23-2012 12:49 PM
Joeseph
05-03-2012 08:13 PM
COE Joe
33
12-11-2011 05:40 PM
Quick Reply: my 84 bronco (pics)
