1/2 ton SAS (Solid Axle Swap) guide
#107
#109
Probably will run the quad since my 79 has quad on the front as well.
Now where will the track bar mount? I guess I will have to weld or bolt the track bar mount up to it then.
On my 79 the front shock tower has the track bar mount attached to it on the bottom.
#112
#114
In my thread the trac bar bracket is under the frame pretty much behind the driver side coil spring.
Do this...
1- Go to my thread, page 1
2- Right click on each of the install pics IN ORDER and then choose save as
3- Move all pics IN ORDER to a separate folder and view as a slideshow over and over until you see the process in your head.
4- Read the how to involved with each pic.
5- Gain knowledge, ask educated questions.
Do this...
#117
Just keep the rear shock.
I think I could use my 79 front shock tower but cut it in half and use the bottom half of it and weld it to the frame...maybe have enough room if I want to ever put a front shock on it for the stock 90 coil bucket's front shock area.
