1/2 ton SAS (Solid Axle Swap) guide
Sorry to bring up an old thread, I just scored a complete 78 F150 D44 axle that I intend to hang on my 94 F150 and I have a couple questions.
If I read what you posted correctly you mentioned that the stock front driveshaft can be reused? My solid D44 has a slipyoke style pinion setup on it. So I can simply just swap the yoke off the ttb over to the solid axle and use the stock front driveshaft? There's no issues with the stock shaft being to short or anything with the truck lifted 4 inches?
I was also wondering about brake lines/flex lines. The setup on my D44 solid axle is a single rubber flex line off the truck, the rubber line goes into a junction block on the axle housing where it splits into two lines and goes out to the wheels. Will my stock 94 F150 ttb brake flex lines bolt to the 78 calipers? Or are different brake flex lines required?
Was also curious about the radius arm mounts. The mounts for my axle were cut in half by the idiot who removed the axle, I'm not having much luck finding stock 78-79 radius mounts, do you know of a online source for them?
I have no first hand knowledge on the d-shaft so I wont comment.
Im 99% sure you need to use the brake lines for a 78-79 D44 but again no first hand knowledge.
I do know JBG has the C-wedges http://broncograveyard.com/bronco/i-...rm-mounts.html
I cant seem to remember how the factory D44 solid's brakes were run. I would just use your factory setup all the way down to where it connects to the axle. Install a T centered on the D44 and hardline out to the knuckles. Then just a short flex hose to the calipers. I really dont like the setup with 2 brake lines running down to the axle. And IMO its not needed unless the truck has front ABS
I'm sure the master of D44 SAS will chime in here soon and give his "professional" opinion.
the solid axles used a single drop setup and the "T" junction the IFS factory used a dual drop from the coil buckets to the calipers, i used that
hey now, that was a dig
The following users liked this post:
#28
i know that sounds dumb but i get excited sometimes and i can't help but jump in.. like the perry mud bog is this weekend, it has me all jacked up to get the swap done so i can have every kink, flaw, or iritation done so i can take my truck next year..
i may have to have a few of you beat me down to keep from starting on it...
#29
there shouldn't be any reason why you couldn't install the front axle ahead of time, least nothing is coming to mind why it wouldn't work. it'd be no different than driving a 4x4 around in 2x, just remember even if you swap to a ttb you will need to lift the rear a few inches with a block kit or an add a leaf.
#30
there are a few guys on here that are experts at beeating off, but i don't know about beating down
i'm thinkin of building my own traction bars for the rear, i know my little 302 isn't going to cause a lot of axle wrap but while i have it down and im working on it i might as well cover all points and be safe..
