its still sitting in my parent's driveway, newest pic you can see the bottom half of the t-136-27 t-case.you can see the rear bumper and custom spring mounts. the frame is not done yet.
I dont remember exact numbers for the 6V, but I think it's up to 350hp in military trim, which would land the tq around 750. The 3304 was in the 250hp range last I remember. Of course, ratings are relative figures until the fuel rate gets adjusted.
if you look closely enough, you'll see an empty engine compartment, oh, and i dont have a frame yet either. i think an f350SD frame, then the Cat 7.2 ish or Detroit 6v53t, depending on what i can get a deal on
C7 Cat is a 3126 which is 7.2 and hp wise anywhere from 180-330
The 3116 is a 6.6ltr
i would go with a 3306 at around 300 hp......i cant remember the displacement, but it was around 10ltrs give or take a ltr. 950-1350ftlbs...runs good.
or a dt530-570. but they are harder an more expensive to find then a Dt466.
a cummins wouldnt have enough power to make it fun.....atleast the 5.9 b series. now the C series 8.3 ltr pulls very good for a medium duty.
run an 8.3 or a 3306 from a garbage truck with a 5spd ally behind it.....that would make a sweet rig
Get a dt466 and i can help you get some killer power figures. I didn't mention the 466, because I didnt think it would be fitting in there too easily. The cat 3126 dont have the best reputation either. I know where you can get a Ford 6.6 for $500 and it may even run.
