Electric Shift On The Fly On GMC 2500
I've been having a minor issue with my work/plow truck. Sometimes the ESOF does not want to engage the four wheel drive. I'll press the 4WD button and the 4WD light will flash about 5 times, then go back to 2WD. It'll do this for a few times and then most time it'll eventually go into 4WD. When it goes into 4WD everything works as it should. Sometimes the problem won't act up for months, sometimes it'll happen everytime I try to put it in 4WD. Any idea on where to start? Is it bad switch, relay, or what?
It's an '02 with the button, not the lever. I wouldn't be too concerned about it other than the fact that I plow with it in the winter and need the 4WD to be reliable. I hardly use the truck other than plowing in the winter and taking it where I don't want to take my F350. It gets about 4000 miles on it a year tops, but is used every few days, so the moving parts do keep working.
Before winter sets in I would get underneath and make sure every electrical connection to the transfer case and front diff are clean and tight. Push button systems use external electric motor actuators to shift the transfer case.
I prefer the lever system, with a neutral position, but you cant buy a truck with it anymore. With manual hubs, those are still shift-on-the-fly.
Jim
Jim
BTFordGuy302
18
01-17-2017 05:52 AM
Steven Stocki
12-04-2016 08:01 PM
hoss khaos
10-03-2016 01:33 PM
