First Time Noob post
#122
#124
On to the brakes
I'm doing the brakes now. I picked up a hurst line-lock kit today. I have to run new brake lines in the front.
I came upon a dilemma with the proportioning valve. I wanted a stock replacement proportioning valve, but the parts guy at my local lordco said they're not making them anymore... I know this isn't really true, but I didn't want to argue with him. Getting a replacement prop valve shipped to me is a pain in the a$$ because I live in Canada.
I decided to clean up the old prop valve. My big issue with the old proportioning valve was that all of the brake line fittings were siezed in place on it. Luckily I just recently discovered the holy grail of penetrating oils on another forum, its a home brew concoction of tranny fluid and acetone (50/50 mix). I got all my fittings removed from the prop valve and cleaned it up a bit. I made myself a little diagram so I can remember what goes where on this proportioning valve. I thought I'd post it for anyone else that may be muddling through brakes on one of these trucks.
#125
#126
#127
removing stuck fasteners
Here's where I found the info on different penetrating oils. It's not a forum after all. Thought I'd put the link up here. There is a comparison of penetrating oils in the middle of the web page that I found interesting.
http://www.crankshaftcoalition.com/w...tuck_fasteners
#128
#129
#132
NiCopp brake lines are easy
I hadn't heard of the nickel copper iron alloy brake line material that is available. It is sold under the name NiCopp. This stuff is really easy to bend. I can use my hands for most of the bends, make small adjustments, fix my mistakes. Easy as pie. I thought I only had steel or stainless steel lines to choose from. I was a little intimidated by the task of forming up all new brake lines by hand until the parts guy sold me a coil of NiCopp. Another benefit is that this stuff doesn't rust-- a real bonus where I live.
#133
wiring the line lock solenoid
OK I've got a couple of dumby tech questions to ask here. Perhaps someone will have some information that can help me out here. My first question is about the line lock. I have all the brake lines plumbed and bled. I am stumped in terms of finding an electrical supply for the hurst line lock. I have been looking at the wiring diagram for my truck for the propper power supply for the line lock. I gather I am looking for the auxilliary ignition circuit off of the key switch, but can't seem to find the right colored wire. I bet there are a bunch of guys out there with lots of experience with auto-electric tech stuff. Hence my qualifying this question as a dumby tech type of question.
(BTW 73 Ford Guy, I liked your idea of the mechanical line lock better, but I already tore into the packaging on my shiny new Hurst line lock... and it comes with a shiny red light)
#134
Engine Head Rocker arm stud questions - yikes
Hey guys,
I read an interesting post on rocker arm studs here (https://www.ford-trucks.com/forums/1...arm-studs.html).
I acquired 2 D0VE - C bare heads a while ago.
I purchased a set of roller tipped rockers comp cams p/n 1411-16 for 125 bux.
The stock rocker arm studs are not deep enough in the threads for the poly locks (comp p/n 4601-16) ($55) I have for these rockers.
I did a little digging in the ARP catalogue and compared the specs on ARPs' replacement rocker studs against some measurements on the stock rocker studs.. I think the ARP 134-7104 studs or the 100-7101 rocker studs are very similar. New ARP studs are likely to run me about 75 bux. Hmmm. Has anyone else used magnum roller tipped rockers on their 460 ford? Any problems with valve-rocker geometry fitment? I suspect I will be fidgeting with rod length after I get the stud issue sorted out.
Last edited by HardkaseDaddy; 02-25-2013 at 10:30 PM. Reason: error I meant arp fasteners
#135
As for aux Power there's a heavy like 1/4" black with little green stripe wire in mine I tapped into and ran to an aux fuse box.
Maybe someone has better idea but mine works.
Or maybe run a relay from battery to aux fuse box with a ignition power trigger wire. Installing an extra fuse box sure is handy.
