Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 09-19-2009, 04:44 PM
whiteaddiction whiteaddiction is offline
Garage is empty, add now
whiteaddiction is starting off with a positive reputation.
Made my first batch. Few Question.
I think everything worked out good, Ofcourse I have a lot of questions but I will try to keep it at a minimum. The truck runs great and quiet. So far.
I am using fry shortening and its getting colder her now so I can't run it for much longer. Does anyone know what kind of mixture I can use with some diesel and or anti-gel additive to be able to run around 20 degrees?
I have also watched many videos on making bio and they all have a different process. So what are you guys using for titration? Alcohol or Methonal. And I was told to use 7.5 plus titration, Is this good?
And whats the long term effects of using unwashed bio?
Thanks for any and all answers.
  #2 (permalink)
Old 09-19-2009, 09:00 PM
Knotwild Knotwild is offline
Knotwild is starting off with a positive reputation.
Hello. I caught your post by accident and I will throw in my 2 cents worth on the questions that I have experience in. There are a couple of other guys who are members who are much more experienced than I am.
We don't have extended cold here in south GA, so I have had success with mixing 20% diesel with 80% biodiesel. Most of my oil is soybean and I plug in my block heater at night. .
I use isopropyl alcohol and I think this is the standard. It is my understanding (and experience) that the oil does not mix well with Methanol, so your titration may appear to be lower than it actually is. I.e. isopropyl will be more accurate. When I have used methanol, my titrations were very low and I had a bad batch occasionally due to the low rates of KOH the erronious titration called for.
I am using 9.0 plus the titration. I went through a period of bad batches (along with others in my area, and others who commented on biodiesel forums) and it appears the KOH can degrade when exposed to air. Therefore, I increase the KOH from 7g/L to 9g/L. I hate bad batches that I have to re-run.
I am not an expert on using unwashed biodiesel. I do know that unwashed biodiesel that has not been through a process to remove the methanol does contain glycerin and soap in suspension. Glycerin and soap (particularly glycerin) will produce a significant amount of carbon which could damage injectors, and perhaps even bearings as it contaminates the oil.
Some people remove the methanol from the biodiesel, allow it to settle for 2-3 weeks, and then run it. I can say from experience that it will clear up into some beautiful fuel, but I still use a low rate of Magnesol as a dry wash to finish my fuel.
Good luck: You are officially addicted now.
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
  #3 (permalink)
Old 09-20-2009, 09:22 AM
Rushmore X's Avatar
Rushmore X Rushmore X is online now
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Quote:
Originally Posted by whiteaddiction View Post
I think everything worked out good, Does anyone know what kind of mixture I can use with some diesel and or anti-gel additive to be able to run around 20 degrees?
Are you getting your oil from the same place everytime? Different oils have different frost and gel points. Safest would be to get same jars and have different ratios in them, 20%, 30%... If the 80% started to get cloudy when cold, it would be time to go to 70%, ect. At least that is what I am going to do this winter. Most of last winter, I ran about a third bio unless it was getting near zero without a probem. Did use Diesel Clean once it was getting down into the teens... Also plugged in @ night.
I run mine throught 10-5-1 micron sock filters after distilling out Methanol and washing with Magnesol, then pump through an absolute filter. Need to update my gallery so I have better pics.
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
Tags
bad, batch, biodiesel, made, methanol, ny, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
