Does the 3V 5.4 gets better mpg then the 2V 5.4?
I talk to a guy at the gas station with a I think a 2000 f-250 2wd reg. cab 6 spd, 4.10 gears and he said he is lucky to see 14 mpg on the highway. I have a 2008 f-250 CC 4X4 auto w/ 3.73 and I have seen 18 mpg on the highway driving 60-65 mph.
Comparisons between the 2-valve and 3-valve engines is complicated by the fact that the 2005+ chassis is so much heavier. In theory since the 3rd valve is on the input side and there is supposed to be better fuel/air mixing with the extra intake valve, maybe the 3-valver gets some better mileage. But you generally won't see it on account of all the extra weight.
Then too, what do I know. I thought you could no longer get a 2005+ with a 3.73 because they were all 4.10's now.....
I usually get 13-15mpg, for my normal driving area & style. I keep a spreadsheet on this and my lifetime average is 13.99mpg with a record low of 10.3 and a record high of 17.6.
Recently I got 16.5mpg between Asheboro, NC and Myrtle Beach, SC. Then I got 11.5 all week driving around town. Then 16.0mpg on the reverse trip.
Now, somebody is bound to claim that you can't possibly get that good mileage and/or can't do basic math. I think you can do that well if you really have enough discipline to set cruise and let everybody pass you. At 64 mph I get 22 mpg with my 7.3L diesel. That's 22% better then your 5.4L which is in the correct ball park for what a diesel should do. 18 mpg with a 5.4L seems doable to me.
However, 14 - 16 mpg is probably more typical of what a 5.4L owner will report. My own fuel economy will drop to 19 mpg at 68 mph which again is 20 some percent better. It all seems to add up compared to my own experience.
In my mind, you are doing quite well in MPG's. My '88 F-150 is getting about 13-14 combined and 16-17 hwy. Your trucks are much heavier and twice as capable as mine and my mpg's are no better.
For those of us concerned about axle ratio's, I've seen a ton of '09 SD's with the 6.4L on the lots running 3.55's and smaller diameter tires.
Tim
Tim
Not really. The 4R100 and 5R110 both have the same last two ratios. (1:1 and .71:1) The variable will be the tire diameter. For instance a stock tire for a 20" rim will be larger in diameter than a stock tire for a 16" or 17" rim. Overall weight, terrain, driving style, fuel type, method or caluculation and etc all play a role in mpg.
I believe it's the much maligned VCT that's responsible for the fuel economy improvement over the 2V engines. I was able to get 20 MPG in my '07 5.4L F150, so 16-17 in a Super Duty seems reasonable to me. Of course driving style is by far the most important thing.
You couldn't get an SRW PSD truck with 3.73s after '08. But you can't compare gear ratios with an engine that makes nearly double the torque as the other. The 6.7L PSD is rated to tow 16,300 lbs with 3.31 gears. The 6.2L V8 needs 4.30s to have the same capacity.
