Alabama Chapter Join Chapter , Leader:
Need 1996 2WD Spindle (and help)
Old 09-20-2009, 08:14 PM
jasonwho's Avatar
jasonwho
jasonwho is offline
Hi from Huntsville. Would anyone happen to have a spare spindle? I have a 1996 F-150, 2WD. The outer bearing's inner race welded itself to the spindle. The truck is north of Nashville, and I need a spindle to replace the one that is on there.
I also need help in how to get it off. There was some sort of collar that came out with a long chisel and hammer. Is a pickle fork needed to remove the bottom one and the one that mounts to the rod / arm thing at 3 o'clock (yes, that is where I am at on the truck repair ability level). :-)
Do auto parts store rent pickle forks?
If I use a pickle fork, will it damage whatever bushing or bearing is inside the connection on the spindle?
I do have the three nuts off.
I am hoping to get the spindle off to try to repair it. If someone has a spare, or knows of a salvage yard that has one, please let me know. If anyone posts before I can call a Ford dealership, what do they usually sell for and are they usually in stock?
Thank you for any help.
Old 09-20-2009, 08:31 PM
jasonwho's Avatar
jasonwho
jasonwho is offline
If I have it worded wrong, someone please let me know. I am not sure if the part where the nut threads on is removable from the part with the "ball joints" (the big metal piece with three arms? I just know "it's broke". :-)
Thanks.
banjopicker66
24
04-08-2013 11:49 AM
4caster
02-18-2013 09:37 PM
CraigOutdoors
03-28-2010 09:28 PM
jman92612
12-19-2004 11:56 AM
Quick Reply: Need 1996 2WD Spindle (and help)
