1967 F-100 project
#572
on
Hola amigo Pat,
Wish I had here, the bed floor that I cut out of my bed, to accommodate the winch gantry sub frame... but it is leaning up against my garage wall down in Baja. You can have it, but you'd have to come and get it... Better to find one in NE. amigo . I have no intentions of ever using it, so there it sits... and I expect for a long while, as not much is ever hauled North out of Baja, back to the USA.
rusted floor along the bed/cab wall<br/>
lifting the bed after cutting with plasma torch
cut line for plasma torch
Winch, gantry, & sub frame on top of chassis.
Wife cleaning up in the background... as always..
Last edited by bajafishnut; 05-30-2017 at 01:14 PM. Reason: to give credit to my wife..
#574
Plant is....idle. Basically, we're just a nuclear fuel storage facility now! I'm hoping I don't find too many more of those spots after sandblasting. I really wish I had somewhere to have this thing dipped, I'd feel better knowing it had all the rust cleaned out. But, I'm not driving to Illinois to get that done!
#575
So now I'm having second thoughts. I was awake at 3 am this morning, thinking about that box. I think I need to take another look at pulling those box sides. I just don't think I can get the rust and crap cleaned out of it, and get everything coated and sealed up without pulling the sides. I think it will drive me nuts if I don't do it. So, I'm going to take another look at that box tonight, and see what it will take.
#576
#578
#579
on
I'd consider pouring phosphoric acid into the cracks, as it converts rust to ferric oxide, from ferrous oxide, and ferric will not rust any more... Several marine applications would work, and I think that Eastman makes a rust converter too. It will turn the rusted area black in color, and stops the surface rust.. allowing you to paint right over it... Good luck on whatever you decide amigo,
Baja
Baja
#580
Brought the bed home this weekend. Got all the trim stuff off, and hit it with the power washer. After careful contemplation, I've made a change of plans. Originally, I was going to pull the box sides, and then get it sandblasted. But, this thing is in such nice shape, and you cannot believe how many spot welds hold those box sides on! So, I'm going to do one last check, and see if there is a dipper within driving distance that can do this box (the guy I go to locally doesn't have big enough tanks). If not, I'll go with sandblasting.
