1988 F150 Running Rich and bad!
#332
You need to take a fuel pressure reading off of the fuel rail. On my '85 F150, 302, the fuel return line to the tank was pinched off, behind the driver's side valve cover, near the fuel pressure regulator. It drove me nuts trying to locate the fault because on my truck there was no fuel pressure connection fitting on the fuel rail, so I was unable to take a reading. I finally discovered it when I proceded to take the upper intake manifold off to check for vacuum leaks. There are two fuel lines that connect to the fuel rail, near the firewall. One of these is the fuel supply line from the tank, the other is the return line.
Good luck!
Norman C
Good luck!
Norman C
#333
im afraid he's taken fuel psi readings about 3 times the last one is
plus he said that the truck ran near perfect when its raining
personally i dont think thats a fuel line problem.. but you never know
#334
#336
Kart how sure are you that you got the right in tank pump unit? How long after you installed the new pump did your problem start? 87, 88, and 89 use the DFR and the in tank fuel pumps are different from what I understand. the 90 and up have some sort of check or diverter valve on the in tank pump unit. Try bypassing your DFR but use the tank you didnt put the new pump in. When running down the road and the missing/jummping starts have you ever just pulled over to the side of the road and see if you smell gas or see it leaking on the ground?
#337
#339
#340
It's in the wiring harness somewhere. I talked to the guys at the garage on Friday and they told me they know what's wrong with it now they just need to find it. Apparently they hooked up the voltage meter to the 02 sensor and by moving the wiring harness around the voltage changes. So they are figuring that there is a bad spot in the wiring somewhere in the harness. Interesting. I guess the rain and dampness (acting as a conductor) is why it ran better. Any comments on this? I sure hope this is the problem and they get it done and that's it.
How much is a wiring harness?
Where do you get one?
How hard is it to change out?
Would it be a good idea to just change the whole thing or just fix this problem?
Thanks, Todd
Thanks, Todd
#342
#343
Yes, troubleshoot the harness. I repaired the one on my 1987 F250 after it had been damaged by fire (previous owner). It was easy to do and there really isn't all that much there.
The local junk yard wanted $30 if I pulled it.
You'll see that Ford uses sections of harness in the engine compartment. The engine harness is extremely easy to repair or swap.
#344
