curious-lift and clearance for you
i have an 03 fx4 ext cab with a 6'' fabtech lift in the front and 4 1/2'' in the rear. currently i have some 35x12.5xr20 on there and there is slight rubbing in the front only when i back up and the wheel is cut all the way to the left or right. i'm buying some 37x13.5x20 this weekend and the only concern i have is maybe the rear rubbing and if it does it looks like it will tear up some stuff because i can just cut some of the front plastic to clear it. anyone have a similar set up? or an idea so i dont have to lift the rear with blocks. i also have the mud flaps still on there that have been trimmed.
i am not sure about rubbing or having to cut the plastic, but i have a 2002 4x4 with fabtech 6" suspecion and i have no problems with rubbing. i installed sum whell spacers in the front and rear. yea the stick out a little but in texas theres no law against that exept extreme stick out like 12 inches.
