FORD to TAKE CUMMINS CONTRACT. from a reliable source
#46
The 7.3, 6.0 and 6.4 Powerstrokes are all common rail. The differance is that the 6.4 is high pressure common rail.
#47
Ford will get cummins think about it...they can grab all the dodge sales and really compete with the duramax/alison combo, sometimes in the project world its better to dump (the scorpion) and become the best, also they could put dodge out of business, FORD wouldn't hesitate to try and do that no matter what it costs, as five years from now they could have 80% of the truck market and charge what they like and recoup any losses no problem....go for it FORD.
#48
The 7.3 in my 03, is a HEUI (Hydraulic Electronic Unit Injectors), not a common rail system.
I know its just wikipedia, but heres a link http://en.wikipedia.org/wiki/Ford_Power_Stroke_engine
and theres lots more info available in the 7.3 forum that corresponds with what Chris was saying that the 7.3 is not a common rail system.
#49
Ford doesn't need to be more competitive then the Duramax Allison, they already out sell them. When you just spent hundreds of millions on an engine and tranny combo this close to release, it DOES NOT make sense to dump all your work, then spend hundreds of millions again making a new engine work just to have the "Cummins" name, especially when you are trying to save money.
Putting Chrysler/Dodge out of business is the LAST thing Ford wants. The economy would be hurting MUCH worse then it already is. The Asian/European car makers would strike and flood the market - taking GM down as well, and if you think Ford (who is already pretty weak financially) can standalone by themselves against the 20 or so foreign brands, you are out of your mind.
@preppypyro, the 7.3/6.0 IS a common rail system. The injectors receive from a common fuel line/source. Fuel isn't being targeted to a specific injector. What the 7.3/6.0 is not, is a high pressure common rail system - which is what the 6.4 and every new Diesel is. Also, that same Wikipedia article says the 7.3 IDI underwent some "changes" to DI, Turbo, and Electronic Injection to become the Power Stroke. I would take anything in that article with a grain of salt.
#50
#51
#52
#54
The only thing the 7.3 IDI and the 7.3 powerstroke have in common is displacement. As said above "common rail" means that the injectors are fed from a single fuel line (or one on each side) this is the same thing you will find on the efi motors. The 7.3 ps and 6.0 are both fired by computer (electronic signal) same as the injectors on an efi. I spent 2 years researching the diesels Ford used in thier trucks before doing my swap. I hate anything electronically controlled and that was my main reason for going with old dependable 6.9 IDI.
#55
Dodge never was a good truck. They had to for cummins. Ford has never changed anything. They are still dependable tough trucks that isnt owned by FIAT. LOL. I personally run both cummins and cat in semi's and the cat motor is a better low end grunt power motor.Cummins and dodge has built junk for years and i have always wished that ford would put a cat in their trucks and run them both out of business. But thats just my opinion.
#56
#57
I dont hate cummins. I have a couple friends that have the new dodges. They pull like they are empty even under a load. I just loved the way a cat pulls out of the hole much better in the big trucks. A cummins was more of an owner operators motor though because they were simple enough to fix on the road. I have just always loved ford and cat and would love to see a combination of both. If nothing else id love to see the dodge boys have to buy a ford to get a new cummins.
Just messin around.
Just messin around.
#59
Oh no if Chrysler goes down, then GM will, then OPRAH, then the U.S. then world will end and then armageadeon. lol.
Actualy what would happen is someone else would buy them out, maybe even keep the name and keep everything running like normal, almost like it never happened. Yeah maybe a few factorys would shut down, some models would stop, some new models would come out. Certain contracts with subcontractors might change..... Oh wait this just happened! Yeah with that one company what was it called, oh yeah it was chrysler and Fiat bought into them to help keep them going with their bankruptcy. Lemme guess you want me to list this info for you too?
Christ the government would step in and buy them out and keep them running, they would never let our economy and overseas economys loose that many jobs and potential proffits. But all you hear is
#60
And ford trucks do not sell out chevy, Remember ford dosent have sub-divisions that also pump out other top of the line diesels like chevy. CHEVY AND GMC together sells more thrucks than FORD all togheter. Evey ford fanatic (which I am) says this all the time...... This you can look up yourself
Ford has so much money it crazy. They could scrap that scorpion like an empty soda can with out blinking and pick up cummins and sit back and watch trucks fly out the door. I'd trade my 6.4 in on a new 5.9cummins powered ford in a hearbeat. I would pray ford ressurect that 5.9 that dodge stoped ordering and let the 6.7 fly by (not that the 6.7 isn't a good engine, just not as flawless as the 5.9. Its been hard for a brand new 6.7 to sit next to a 5.9 thats had the bugs worked out years ago and has been proven through and through for over 15years!
