Need Help in North Texas!!!!!
I have a 2001 F-150 4.2l i took to a local garage to have some head gaskets replaced. I was told that my heads were warped and they needed to be replaced. I had the garage replace the heads w/ new?heads, gaskets and such. I had them replace the water pump cuz I figured it would go as soon as I got it back. The place charged me for 1 set head gaskets=$300+,2 heads=$297.50, 1 set head bolts $26, intake manifold gskt set $12. They then told me they had to replace my plugs=$4.98each and thermostat $12.90. picked up my truck and drove it...just about 1000miles and less than a month after i had it fixed, I threw 2 rods through the oil pan on the hwy, had it towed back and was it was not anything they did but they would fix it for another $2400, when i questioned what had happened i was told off and to go ahead a sue him(which I never brought up). I now need EXPERT witnesses PLEASE ANY HELP would be appreciated. I know I was done wrong and I am now fighting for the little guy!
Thanks
Thanks
Thanks
Thanks
Sounds like you definetly have a lawsuit if you want to persue it.
Anytime you tear into an engine - you change the oil and filter.
And they are definetly resposible for the head gasket leak after only 1000 miles.
This of course assumes you did not tell them to skip any steps or do it as cheap as they possibly could.
