I lost the full XLS decals when I painted it unfortunately, I looked and looked....but no one does the decals
It's possible to reproduce them but it is time consuming for what you have. I see two colors for sure, orange and gray?, and I assume that the black section in the middle is just the body paint. The "XLS" at the end of the bed adds work too, and I assume you didn't save any dimensions and close up pictures before painting it?
I plan on making the stripes for my truck but I just have two stripes down the side and I still have them on the truck to take measurments. My boss has a 28" vinyl cutter at work, I just have to buy the roll of vinyl. I'm not sure how good it will work for a long stripe, the vinyl may not feed straight enough because it feeds back and forth to make the cut.
Sw1tchfoot....it's not so much the striping but the "XLS" which is etched in to the vinyl. Other than that it should be fairly easy to replicate on doors and fenders, the rear flares would be tricky. I still have the old flares with the original stripes so it possibly can be done....by someone with more skill than me!
It's -38 this morning,,truck starts no problem,,mind ya I got a block heater along with battery tender as well as dual batteries,,but it starts! And throws plenty of heat in the cab,,did i mention it STARTS! 1985 4x4 4 speed 300 duraspark 11
