You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
The Marshmallow needs tires and I can't find Rims to fit.
Help!
I'm looking for steel rims to fit my van and the Nitto tires?
See details below.
I recall hearing that there is only one company that makes DOT certified bead lock rims for light-trucks, anyone remember that post / know of the company?
Because I'm a 2006 van, I have an 8 by 6.5" bolt pattern.
Although there is a 2006 F350 front axle (8x170mm) its drilled & studded to match the rear axle's 8x6.5" pattern.
From what I've learned I need F350 wheels from 1996 and earlier to get the 8x6.5" bolt pattern.
From the few rim sites I've been to they don't offer a look-up for vans, just the various pickups, and even then they don't list the 1996 and early earlier model years.
The Nitto tires I'm eyeing are E-series 4000# +/- and aluminum rims are not up to it.
Nitto Dura Grappler LT285-75R17 E 128R
Stock Number 205-370
Tread Depth (1/32") 16.9
Inflated Overall Dia. (In.) 33.86
Overall Width (In.) 11.61
Approved Rim (Measuring Rim Width In.) 7.0-(8.0)-9.5
Maximum Load Press (Weight Lb. @ Psi.) 3970@60
Revs per Mile 614
Nitto Terra Grappler LT295-70R18 E 129Q
Stock Number 201-130
Tread Depth (1/32") 16.6
Inflated Overall Dia. (In.) 34.41
Overall Width (In.) 11.77
Approved Rim (Measuring Rim Width In.) 8.0-(8.5)-9.5
Maximum Load Press (Weight Lb. @ Psi.) 4080@60
Revs per Mile 604
Now for why the urgency?
My van, which is still being otherwise worked on, had the vibration at 55 - 60 MPH diagnosed to the right rear tire which knotted up its sidewall belts. That likely started along time ago while I had my toolbox in the back and has been deteriorating since.
I can't see replacing just the one tire, which leaves me exposed to doing it again the next time I have my toolbox in the back.
Thus the upgrade in load carrying to the high end of the E-Series if not to truck tires in the F - G - H series.
__________________
Dave ~*~ Mods are listed in my Gallery (Updated 03/11/2010) Former Connecticut Chapter Leader Feb. 06, 2009 to Aug. 22, 2010.
2006 E35Q 6.0 5R110 35.4" Tires & 5.13 Diff., Unicell's Aerocell SRW body with Quigley 4x4 Conversion - - - 2004 Expedition XLT 5.4L 4X4 4R75W 3.73 Posi
Prior: Courier Pickup and a 1991 Crown Victoria Interceptor
__________________
I was interested in a DOT certified bead locks in conjunction with the Nitto tires as they can run under inflated.
The Trail Ready site doesn't mention DOT certs and only speaks about off roading.
As for the Hutchinson's in my post, they can't carry the weight.
I don't know if the Trail Ready's can carry the weight, but I've decided over the past couple days to go with the Rickson Truck 19.5" rims, and so I won't research the Trail Ready's for their ratings.
Thanks again Aaron, I appreciate the link.
__________________
Today, I finally connected with them and discussed at great length their product and my van and various hear-say.
I should be getting a quote by email tomorrow.
What I learned is that they are operating on a reduced staff due to the economy, but all is well even to the point that that are looking to hire someone.
What I spec'd out is:
Five rims and four chrome trim rings, so now I'll have a spare tire.
Commercial truck wheel pressure monitoring (as Hella's won't fit the larger valve stem ports that Rickson uses, plus the Hella's are not ranged for the higher pressures used in truck tires).
Half-inch positive offset for a wider stance to compliment the increased ride-height Michelin XDE2+ 285/70R/19.5
Diameter (unloaded): 35.4" which provides a 2.45" taller ride than factory equipped.
Overall Width: 10.9" which is 1.3" wider that originally equipped.
Max. Load @ Single: 6395 pounds, though the rims are only DOT rated to 5000 pounds
Tread Depth: 21/32"
Revs. per Mile: 587
In comparison, my van came factory equipped with LT245/75R16 Load Range E (3042 Lbs @ 80 psi) which have a 30.5" diameter, with a section width of 9.6" and a section height of 7.2".
Rickson's rep also gave me some info concerning my van.
The cutaway chassis is factory equipped with a rear axle used for DRW and therefore my van already has greater breaking capacity than found on 'standard' vans. They don't believe I'll find the need to beef up my brakes, they feel the OEM brakes should be sufficient for the larger size & weight of the tire / rim combination being ordered.
I could have these in a week or two from when I accept the quote.
__________________
