Should i use rtv???
Welcome to FTE. You for sure want to tack it down to the valve cover with a light bead of RTV. Whether or not you put a bead on the cylinder head flange is up for debate, I'd try it without first. The important thing is that you torque it down gently and evenly to specification, without overtightening. If the valve cover flanges are not flat, they won't seal. Big thing to remember with a cork gasket is that you have to re-torque it a couple times after it sits for a little while each time, because the gasket will relax. If you didn't do this the first time, that may be why it's leaking.
also if you continue to have problems with your cork gaskets leaking and for some strange reason the RTV doesn't stop any leaks another option would be to yet again get a new set of gaskets and some gasket sealer I have found even though a valve cover gasket should be oil resistant some manufacturers are cheapskates and they aren't so the sealer helps a bit
I would lay odds on the valve cover flange being bent or otherwise distorted. If they were previously overtorqued they may naver seal until they are repaired.
I hate scraping the old stuff off and never use any type of sealant. Straight covers, even stamped steel ones will seal fine if they are straight.
granny_rocket
10-23-2013 10:47 PM
CCotten
10-12-2005 09:29 PM
bulabula
03-17-2002 10:02 PM
