Metal on Metal scraping noise
Old 08-04-2009, 09:33 AM
tuckerbask's Avatar
tuckerbask
tuckerbask is offline
I just had my 2001 Ranger, 4 cyl. standard inspected last week. But on my way to the mountains - I heard a metal on metal scraping sound when I came downhill into a curve - it only happened once. I did not use my truck all weekend, but upon my return from the mountains, I heard the sound again two or three times. It sounds like metal pipes rolling into each other when it happens. And it seems to only happen when in a curve. It doesn't seem to relate to using the clutch or transmission as when shifting on the straightaway, there's no noise. Thank you.
Old 08-04-2009, 11:22 PM
g_k50's Avatar
g_k50
g_k50 is offline
It could be the brake scraping on the caliper due to centripetal force. The turning of the wheel in the curve combined with the rotation of the wheel causes the rubbing.
Look for shiny spots in the suspension area while the wheel is off.
Old 08-06-2009, 05:48 AM
theone1's Avatar
theone1
theone1 is offline
Banging of pipes sound
Could be a broken motor mount! if it only happens on a curve in one direction. The exhaust pipe could be hitting something. Centrifical force.
Old 08-06-2009, 05:06 PM
BigD01's Avatar
BigD01
BigD01 is offline
check heat shield on converter, as it may have worked loose
Dave
Thumper19
53
06-06-2022 06:36 PM
fordtrck302
1978 - 1996 Big Bronco
02-21-2015 11:13 PM
snoopt1
1997-2006 Expedition & Navigator
07-02-2011 01:50 AM
Silverdawg
Escape & Escape Hybrid
06-14-2009 08:02 AM
Quick Reply: Metal on Metal scraping noise
