Hub change and I found this. Plus a ?
While pulling everything apart to change my ball joints, I disassembled the passnger side and all was good. But when I took apart the drivers side I was greeted by this.
Missing parts! It seems that the last time I had someone fix my ball joints they forgot to put in all of the washers. They also installed the washer that has the four groves in it backwards.
This is what should have been inside when I took it apart.
WTF!
It seems that there is some metal shavings on the drivers side hub that I removed.
So I actually have three questions. First does anyone have the part numbers for these washers?
Should I replace my hubs now due to the possibilty of damage?
The final question is, is there an easier way to remove your axle shafts or do I just need to be patient pry them out?
Thanks.
WTF!
Thanks.
Try the our FTE Parts Guy for the stuff you need.
I would replace the hub.
Be patient. It will come out. Try this link for a few tricks. Scroll down to Axle Removal.
http://www.thedieselstop.com/content...20Installation
a pry bar prying out on the back side of the u-joint, on the longer stub of the axle, usually pops them right out. I just replaced my hubs because like that, i put the large 4-tab washer on the hub locker side of the hub, and not on the knuckle side where it should have been, and i found a pile of shavings when i went to do my gears!
There is nothing in the hub that the shavings will tear up. Just pull the hub apart, clean the trash out and re-grease and it should be fine.
The 3 small washers will come in one kit and the large grooved thrush washer in another. Ed, FTE Parts Guy can fix you up on both, sorry that I don't have part numbers.
Thanks to all for your help. It is going to be a while before I can finish this up. I do not have a garage and it is raining again.
then the F81Z3B458AA & D8TZ1B093A are the washer for the stub shaft, 4C3Z1K106AA kit has two orings and a large retainer ring.
F81Z4A322AA is the yellow oring
Ford does not give me a exploded view of the 1104 hub assy.
I think you can replace the inner roller needle brg in the hub with C6TZ3123A
I'll continue to look and see if I can come up with a better pic of hub.
ed
ed
then I will continue searching.......
the catalog does call the F81Z3B458AA a washer PACKAGE?
i'm going to call around and see whats in the PACKAGE.
no one I know has the washer, so i'm going to order one and see what comes in it.
ed
