what ever happened to the rockwell rig you had last time you stopped in? and i'd guess you're kicking cancer's ***? if so, good deal!
I sold that to one of them dirty Canadians. This is the last I saw of it. Still cancer free
Originally Posted by 460 FORD MAN
Nice flex, how much lift you running? What size are the rear tires?
Not sure how much lift it ended up being. They're stock 63" Chevy springs that have been mounted underneath of the frame, instead of outboard. Probably about 5" if I had to guess. 42" rubbers
New rear bumper almost done with hitch reciever and sliders all stick welded up. Jacked the truck up the other day wit a highlift on the sliders. Heres a picture of flex from today too, 6"superduty lift springs and stock rears, will be going to stock b code rears real soon. The rear tire isnt quite touching the ground in this picture, seams as tho longer shocks are in order too. Flex was maxxed out for the old girl, might measure the block it was on tomorrow, i know it was quite a bit larger than the 38s.
