How Do I Tighten the Transmission Selector on the Steering Column???
This has been on my list of to-do's since I bought this truck. It's obvious that the guy who owned it before me rested his hand on the transmission selector switch (on the steering column) while he drove. It is noticeably loose. It doesn't affect gear selection or transmission operation, but when it's in the drive/overdrive position, the needle almost points to the "2" position. I've looked under the truck and the connection to the transmission seems to be solid. Is there an adjustment there I can play with to tighten it up. Maybe in the steering column? Can I tighten this up or am I just stuck with it?
Any information is welcome. Thanks in advance.
EDIT: I just found the shift indicator cable adjustment in my shop manual. I'm going to try that, but does anybody know the purpose of hanging a 3lb weight on the gear shift lever?
There are two bushing on the shaft that comes off of the gear shifter and these tend to go bad and give the slop. I had to replace mine. Here is a picture: http://s481.photobucket.com/albums/r...t=IM004867.jpg Also here is a picture of the indicator selector adjuster: http://s481.photobucket.com/albums/r...t=IM004866.jpg
I'll give it a try tomorrow. Going camping so things are busy between work and packing to leave tomorrow. I'l probably try it tomorrow night at the campground (with a beer ). Hopefully it's just the adjustment and not the bushings, otherwise it will have to wait until Monday .
Thanks for the quick replies.
Maybe there's an adjustment you can do at the transmission. You can see where the cable connects to the selector on the tranny (it's on the driver's side of the tranny under the truck). There might be some kind of adjustment there. Just a thought.
So I adjusted my orange indicator needle with the **** in the dash. At least it indicated "D" when I'm in it.
How much play should be in the selector handle? If I jiggle the handle when it's selected to a gear (1, 2 or D/OD) I easily have 1" of play in the handle. Is this normal or should I be figuring out how to tighten this?
Posted by Roland (Mueckster) on FTE 4-17-2009
Thanks Roland
Cable and Bracket Adjustment
Place the gearshift lever in the (D) position.
Place an eight pound weight on the gearshift lever. (Just apply some downward force on th lever)
Raise and support the vehicle.
Disconnect the transmission shift cable from the manual lever. (Lever on left side of Trans)
Unlock the lock tab on the transmission shift cable.
Place the manual control lever in the (D) position.
Place the manual control lever in the first gear position.
Move the manual control lever two detents to the (D) position.
Connect the transmission shift cable to the manual control lever.
Lock the transmission shift cable lock tab.
Lower the vehicle.
Carefully move the gearshift lever from detent to detent and compare with transmission settings. Verify that the vehicle will start in PARK or NEUTRAL and backup lamps illuminate in REVERSE. If not, Steps 1-5 must be repeated and include digital TR or TR sensor adjustment in NEUTRAL. Readjust if necessary.
This picture may be showing the direction for re-latching the tab, but you get the idea.
Thanks Roland
Lower the vehicle.
