FX4 satellite radio questions
I am in the process of ordering a '10 FX4 through a traveling salesman overseas, without the benefit of seeing the vehicles in person, and the salesman himself doesn't seem to have very good information, several things he told me were flat out wrong.
At the moment I'm seeking answers to a few questions regarding the radio.
1. Salesman told me that the navigation radio could function as a computer, with work solutions software available from dealers stateside.....I can't find anything to verify that, is it true?
2. If I get the navigation radio, will the truck still come with am/fm radio?
3. Do I need the screen fromt he navigation radio in order to use the back up cam, or is there some other way for that to function?
4. The navigation radio seems a bit steep in price, is it generally considered worth it from those who've used it? Does it take away fromt he interior if it's not there?
5. Can a six disk changer be used in conjuction with the navigation radio?
6. The brochure says that in dash six disk cd with satellite radio has limited availability in FX4's. Would it be available in an FX4 SCREW without the navigation radio?
Thank you very much.
1. Salesman told me that the navigation radio could function as a computer, with work solutions software available from dealers stateside.....I can't find anything to verify that, is it true? No they are 2 different radios.
2. If I get the navigation radio, will the truck still come with am/fm radio?yes
3. Do I need the screen fromt he navigation radio in order to use the back up cam, or is there some other way for that to function?No but it's a lot better through the nav unit
4. The navigation radio seems a bit steep in price, is it generally considered worth it from those who've used it? Does it take away fromt he interior if it's not there? Dash looks nicer with the nav unit as there a lot less buttons and the nav unit coupled with the sony speakers and sub make a very very good factory system. Im well impressed with mine
5. Can a six disk changer be used in conjuction with the navigation radio?Im not sure but the nav unit has a system where you can copy discs to the nav unit so you can store them and delete them as you like and it will hold a lot of music in mp3 format.
6. The brochure says that in dash six disk cd with satellite radio has limited availability in FX4's. Would it be available in an FX4 SCREW without the navigation radio?You should be able to get sat radio witout nav
Hope this helps
MonkeyFarmer
1999 to 2016 Super Duty
11-18-2013 07:43 PM
brad-sc-ss
2004 - 2008 F150
06-20-2013 11:27 AM
Awake79
08-02-2012 03:58 PM
