Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 10-09-2009, 04:11 PM
grandmas77f150's Avatar
grandmas77f150 grandmas77f150 is offline
grandmas77f150 is starting off with a positive reputation.
Truck's looking great. It makes me anxious to get neck deep into Grandma's Truck. I just gotta finish the flatbed now.
__________________
01 Ranger Edge 4x4 Supercab
77 F-150 4x4 351M "Grandma's Truck"
77 F-250 4x4 400M - Work in Progress
  #32 (permalink)
Old 10-16-2009, 03:14 PM
ranger429 ranger429 is online now
ranger429 is gaining momentum as a positive member of FTE. ranger429 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 78_f800crewcab4x4 View Post
dont forget to spray rust proofer on the underside edges/corners of the roof panel/drip rail area, they rust out fast as there is no paint in there.
Already had planned on that, thanks.
Quote:
Thank you.
More progress. I finished up the roof, what a major pain that was. It is pretty flimsy and made it very hard to sand.
several coats of filler all hand sanded with the longboard.
Final coat of filler, waiting to be sanded.
Then finish it off with a coat of spot putty. This needs to be sanded as well.
Finished and ready for primer.
Looks 100% better without those cheap cab lights. I am going to try and find a set of LED cab lights that will look nice to put on it.
And last but not least the driver side door, it has a final coat of spot putty that needs to sanded yet also.
On both sides of the upper bed rail I had to redo 3 of the 4 stake pockets. They were pretty busted up so I reshaped the holes. Both sides of the bed rails had a bunch of dents in them as well so those needed some straightening.
So as it is right now I have one spot left on the lower passenger bedside that needs to be done, the back of the cab needs to be sanded, the passenger rear door needs to be hung and checked, hood needs to be finished and I need to finish up the cowl. Once those are done I ready to spray some primer.
__________________
_____79 F-250 429 36" Cepeks____79 Bronco 400 35" Cepeks_____
____________79 F-250 4x4 Crewcab, under the knife____________
  #33 (permalink)
Old 10-16-2009, 03:30 PM
b-uno's Avatar
b-uno b-uno is offline
b-uno is gaining momentum as a positive member of FTE.
wow! how many gallons of bondo did you end up using? was it rolled or somthing? is that why theres so much in the roof?
__________________
"LOOK AR ME!!!"
  #34 (permalink)
Old 10-16-2009, 03:35 PM
It wasn't rolled, hail damage maybe, careless loading of stuff in the bed, who knows. These roofs are very flimsy and thin so it doesn't take much to dent them. When the holes for the cab lights were welded up some warping of the roof occured as well up front. If I had more patience I would of cut the roof out and put a van roof in but I just wasn't up for that challenge.
How many gallons of bondo? It really isn't that thick. So far on the entire build I have gone thru 5 quarts of bondo and probably sanded off 50% of it.
__________________
  #35 (permalink)
Old 10-16-2009, 03:40 PM
b-uno's Avatar
well its looking good! im afraid of the day i try to make my crewcab look nice.. i got a dent in the roof and all stake pockets torn and bed sides dented like mad.. I think i will just keep driving it, seems crazy to try to fix all my problems.
__________________
"LOOK AR ME!!!"
  #36 (permalink)
Old 10-16-2009, 03:56 PM
jb10 jb10 is offline
jb10 is starting off with a positive reputation.
looks great! you have a ton of patients. pays off though.
__________________
1978 F-150 4X4, 400M, C-6
  #37 (permalink)
Old 10-16-2009, 04:48 PM
abert abert is offline
1977 Ford F-250
abert is starting off with a positive reputation.
This project has me looking at craigslist for crews in my area. very nice work by the way.
  #38 (permalink)
Old 10-16-2009, 08:26 PM
79fordtruck 79fordtruck is offline
79fordtruck is starting off with a positive reputation.
Ranger429 did you mig or tig weld all of your repairs?
  #39 (permalink)
Old 10-16-2009, 08:52 PM
Thanks JB and albert. All welding was done with a mig.
__________________
  #40 (permalink)
Old 10-16-2009, 09:48 PM
ranger429 i almost forgot. are the lmc replacement panels in your opinion good quailty? i've never ordered from them.
  #41 (permalink)
Old 10-16-2009, 09:56 PM
I only used the inner and outer lower door panel. The inner door panel fit OK with some mods, it was to long on the bottom end, not a real big deal. The outer skin fit perfectly with no problems. You have to remember though I took a complete door section and had to cut it down to size to fit the shorter crew door. I have no idea how it would fit as a direct replacement for a front door. As far as thickness goes, it is just as thick as the OE panel was. I'd use them again.
__________________
  #42 (permalink)
Old 10-16-2009, 10:07 PM
thanks for the information, photos, and your rebuild thread! great trucks by the way!
  #43 (permalink)
Old 10-17-2009, 02:26 AM
WoodGrain's Avatar
WoodGrain WoodGrain is offline
WoodGrain is starting off with a positive reputation.
Well hot damn. If we all won the lottery, Ranger, you'd be the man to call. I give you kudos sir. I'm slowly learning my stuff. I'm pretty much using my GI bill to pay for schooling to learn how to weld and bend some sheet metal.
I want to take my 78 and put a 73 grill on it, drop it down a few and put down about 500 horsies on the rear and look classy doing it. I've got all the parts bought with my "Iraq money". Just have to learn the body and paint portion. Then its on like donkey kong.
Good job on your trucks dude. Glad to see someone with my passion and the level of skill I wish I had.
__________________
1978 F100, 302, C-6, 9" rear with locker, Torq Thrust wheels, and a pretty sweet stereo. Got plans on putting a stroker 351 with a built C-6 to handle the hot nasty badass speed.
  #44 (permalink)
Old 10-18-2009, 07:18 PM
Thank you guys.
I had a couple hours to burn today so I took the NOS doors and fenders down and fit the driver side. I also have to prealign the side molding and drill the mounting holes for the mirror blind nuts. Once they are set in there final place I'll drill a pilot hole thru the hinges to the cab so when it comes time to remount the doors it will be a little easier.
__________________
  #45 (permalink)
Old 10-23-2009, 12:55 PM
The progress thru the week so far.
Got the hood sanded with 80 and then went over it with 180. Had a couple of small dents to fix and some rock dents in the front. It is now ready for primer. I have to pull the hood and decide what I'm going to do on the inside. It is the worst part of sanding this truck.
I also took off all the bondo that was covering up a dent in the lower rear corner of the bed. I sure am glad I took all of the prior bondo work off this truck. Whoever did the previous work sucked at preparation.
Passenger doors are on and lined up. Couple small dents in the rear door that needed some attention.
So if I get the back of the cab sanded, the front of the box, fix the dent in the bed and sand down the OE primer on the passenger door and fenders I think it is pretty much ready for some primer.
Went down this morning installed the strikers and latches and got the side trim drilled and mounted. I also was going to mount the mirrors but I have to find the correct tool to put in the nutserts.
__________________
Tags
1973 , 1979 , 4x4 , 76 , 79 , ac , build , cab , crew , f250 , ford , pics , sale , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
