Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > British Columbia
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
British Columbia British Columbia
Join Chapter, Leader: Zip
  #1 (permalink)
Old 07-17-2009, 12:18 AM
Vinford's Avatar
Vinford Vinford is offline
1979 Ford F-250
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
Any VW mechs here?
Ive got that VW dune buggy and its leaking oil out of the transaxle.
Looks like there must be a seal in there somewhere?
Its a old VW , do you think I can still find parts somewhere?
Anyone ever change one?
Thanks
  #2 (permalink)
Old 07-17-2009, 02:15 PM
Zip's Avatar
Zip Zip is online now
BC Chapter LDR
1979 Ford Bronco
My Garage
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
Never had the pleasure of tearing into a VW. Probably nothing at the wreckers. Chucks should be able to find something for you?????
Gotta be parts out there somewhere though.
__________________
Chris,#12 BS'er/Official Slackmaster #7/AVIDEST WINTER HATER
BC Chapter Member/Leader
JOIN THE BC CHAPTER HERE
  #3 (permalink)
Old 07-20-2009, 01:23 PM
mutant's Avatar
mutant mutant is offline
Garage is empty, add now
mutant is starting off with a positive reputation.
VW mech here
I used to work on the old VWs for years. VW trannys can be tricky. Is your tranny one with CV joints or the older stiff axel type? It looks like the older type (better for off road). Where is the leak specifically coming from? There are gaskets behind each axel base plate and there is a gasket behind the gearshift housing and there is a gasket between that and the gear carrier housing. You could make those gaskets given a large enough piece of paper gasket material. There is also the seal around the clutch shaft behind the motor. Parts are getting much harder to get for the older stuff in Canada. Yoy may have to order from wolfsburg west in the US. I don't know if Worldpac will have anything. Since Bow Wow closed it's doors, easy access to good older VW parts is difficult.
Mutant
'96 F350 4x4 crew:Headmann, Jet,BBk, AirRaid, K&N,Flowmaster, American Racing.
__________________
--Heaven will be inherited by every man who has Ford in his soul--
http://www.angelfire.com/realm2/autotips/index.html
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
