Fuel pressure regulator allen screw size?
Does anyone know the Fuel pressure regulator allen screw size?
It is the aluminum allen screw that holds the fuel pressure regulator plate down. I was checking the little spring for gunk and dropped the allen screw way down in the engine. Since it is not magnetic, I can't use the magnet to get it. It would be easier (I hope) to just buy a new one.
The full kit, plate, spring, plunger, and screws are $56 at the dealer. The spring was clean as a whistle so I don't need a new kit, just the one screw.
Thanks in advance!
Thanks in advance!
I have an extra if you can wait for it? If not it is a 5mm/ .8 pitch, hope that helps.
AlChalmers10
10-17-2011 01:34 AM
96_F250_Deezal
09-22-2011 04:24 PM
