brakes a still soft booster/cylinder have been replaced are there any other components? I adjusted them all the way out maby too much but are still soft some help on this would be great thanks.
Bleed the brakes again. A soft pedal is almost always air in the lines...or a master cylinder that wasn't bench bled properly. If the booster or vacuum pump were shot the pedal would be rock hard.
