03/ Early 04 ICP Swap
Old 05-21-2012, 06:09 PM
Piolet's Avatar
Piolet
Piolet is offline
That is the IPR, it is not a sensor but technically an actuator.
Cost to buy one is from $200 to $250 I think.
  #62
Old 06-27-2012, 09:42 PM
Big Friggin Piece's Avatar
Big Friggin Piece
Big Friggin Piece is offline
So I'm reading everything. I bought a 03 to replace my 06 that was totaled...I paid $2200 for the truck (needs a tranny) but when I started it at the dealer it was PUKING oil from the drivers side of the motor (ran for 10 minutes and lost half a quart). I'm debating on just yanking the motor and transmission out of my 06 and putting it in the 03, but it would be really nice to have an extra motor just incase of a rainy day. I notice some are replacing the ICP for check engine and running issues, but is it possible this is leaking oil?
  #63
Old 07-21-2012, 02:52 PM
rsmith77525's Avatar
rsmith77525
rsmith77525 is offline
ICP SENSOR
I have 2004 Ford F250 and can't find the icp sensor anywhere. Can anyone please help me?
  #64
Old 07-21-2012, 04:07 PM
Piolet's Avatar
Piolet
Piolet is offline
I put a video on here a few months ago showing exactly where it is on an early model 6.0.
Search for ICP video or location or something similar. The video walks you right up to it.
  #65
Old 07-21-2012, 04:41 PM
rsmith77525
I couldn't find the video.
  #66
Old 07-21-2012, 05:04 PM
Piolet's Avatar
Piolet
Piolet is offline
Top of page there is a search function. Type in ICP VIDEO and search "only in titles" and search only in the 6.0 forum. It's the first result in the search. I'm working from my phone or else I'd paste it for you.
  #67
Old 07-30-2012, 08:09 PM
qdrider01's Avatar
qdrider01
qdrider01 is offline
Hey guys, i have a 2003 6.0 l which my check engine light came on and threw code for ICP . I noticed it been idling weird and would surge at times but had no dash light on yet. Ive read many posts about how to change it, its a damn good thing i have skinny arms because i went at it from the bottom. I still have to buy 1 1/16" wrench to loosen then install new one but im glad i went the way i did, saved alot of time and wrenching... Just thought i'd post and let u guys know i couldnt do it without you guys! This forum is the most helpful and interesting fixes on the web, thanks to you all!
  #68
Old 02-13-2014, 07:10 PM
jimmyb0475's Avatar
jimmyb0475
jimmyb0475 is offline
i know this is probably a dead post but i just had my hpop and icp replaced about 6 months ago and now the truck is doing the surging thing but has not thrown any codes while on the stock tune. I have a late model 2004 and i know the head gasket is bad, anyone have any ideas
  #69
Old 02-13-2014, 07:13 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,392 Likes on 2,089 Posts
Does it surge at idle and is your ICP on the passenger side valve cover? Was the pig tail oil soaked? You can always unplug it and let the ICP default.
Welcome to FTE Jimmy
  #70
Old 07-31-2014, 03:16 AM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
Ok those ideas about the 3/8 fuel line and taping the wobbly joint were strokes of brilliance! Those two items saved me tons of time. I let this go for month's because I dreaded fighting it. Sucker was puking a half quart of oil every time i parked it lately.
  #71
Old 10-06-2014, 11:53 AM
wingrider75's Avatar
wingrider75
wingrider75 is offline
Just finished this. Wanted to add another tip. I discovered that you can use a regular length 3/4" drive socket and tape a 1/2" to 3/4" adapter in to the socket about half way, the socket will fit over the sensor and you can get the darn thing in and out. This cuts the length down quite a bit, and only required one small dent in the heat shield. And I didn't have to cut down a 1/2" drive socket to fit. I didn't have one to try, but I suspect a 3/4" U-joint followed by the adapter would have worked well in the socket as well, and maybe better. I did have to find a friend with smaller hands to get the darn wire plugged back in though.
  #72
Old 05-05-2016, 05:14 PM
Trader55's Avatar
Trader55
Trader55 is offline
ICP Change from the top
First, the thank you's, especially to william_04_x. Without the thorough write up I would have been really lost. Also, all the other posts were very helpful. I went in from the top for two reasons: I got under the truck and really didn't think I could reach the sensor. I also wanted to replace the pigtail, and wasn't sure how much dis-assembly would be required to do that.
Second, I did not say anything nice about the designer of this ridiculous (cleaned up for the post) place for a sensor.
All in, took me about 5 hours.
Dis-assembly: 1 hour.
Get sensor out (excellent tip to tape the union and the socket) about 30-45 minutes. Part was taking a break.
Get new sensor back in: 1 hour. Did the hose trick, but still had a problem getting it started. I pushed a 5 inch punch into the hose to stiffen the hose and hold it straight. Went right in.
Replace pigtail, re-connect sensor: 1 hour plus. I am glad the designers mother wasn't around.
Reassembly and clean up: 1 hour.
I only had (1) 10mm nut left over. Pretty good for me. Still can't figure out where it came from. It's not the ground wire, I got that one.
Thanks again everyone! I don't know if it's a placebo effect, but the thottle does seem to be more responsive, and no surging!
  #73
Old 05-05-2018, 12:44 PM
jacko444's Avatar
jacko444
jacko444 is offline
Just replaced my sensor and WOW, what a pain it was. There was a lot of great tips on this thread and want to thank you all. I'm also going to add one more tip. I cut down my deep well 1 1/16 socket and still wouldn't fit cause it was hitting that heat shield and wouldn't seat onto the sensor properly so then I pulled out grinding wheel and tapered the back end of the socket and still wouldn't work. Then I got pissed off and grabbed a hammer and pipe and tweaked the heat shield a little bit. That's what worked. So my tip, do not mess with cutting up perfectly good sockets.. just reshape the heat shield for access.
  #74
Old 12-26-2018, 04:01 PM
scottyscheff2380's Avatar
scottyscheff2380
scottyscheff2380 is offline
Nearly 60 year old with arthritis appreciates this write up!
  #75
Old 12-26-2018, 06:14 PM
Maxium4x4's Avatar
Maxium4x4
Youngster..... Glad you found the information helpful.
Quick Reply: 03/ Early 04 ICP Swap
