Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 01:39 AM
John - NNY John - NNY is offline
John - NNY is starting off with a positive reputation.
Brake linnings???
I found a two sets of NOS brake shoes. They appear to be the woven type. I have heard that . . .
"Woven linings should only be used on the original steel drums. Do not use woven on cast iron drums. Use bonded brake lining on cast iron drums. Do not use bonded linings on steel drums. Mismatching brake materials on the steel & cast iron drums will cause an assortment of braking problems, but the most disasterous problem is severe brake fade when the linings are used with the wrong drums."
Does anyone have more info on this? Are these linning considered to be the woven type? This is for my 1930 AA.
John
NNY
  #2 (permalink)
Old 07-03-2009, 03:31 AM
Julies Cool F1's Avatar
Julies Cool F1 Julies Cool F1 is offline
Posting Princess
1951 Ford F-100
Julies Cool F1 has a good reputation on FTE. Julies Cool F1 has a good reputation on FTE. Julies Cool F1 has a good reputation on FTE.
Hmmmm- never heard of this before. Every brake drum I've ever seen is cast. But maybe in 1930, they used steel drums - don't know, but I'll bump this up for you.
Edit note: Here is a better picture of Woven linings:
And molded linings:
I would say you need to decide (or express to us) what your drums are.
Here's a manufacturer that says yo ucan use the woven linings in almost all applications, but I'll let you check it out:
http://www.frictionproducts.com/brakelinings.html#woven
__________________
Best wishes
Julie!
  #3 (permalink)
Old 07-03-2009, 10:46 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
ALBUQ F-1 is gaining momentum as a positive member of FTE. ALBUQ F-1 is gaining momentum as a positive member of FTE.
"NOS" in the strict sense means Ford original equipment replacement parts. If these were Ford parts there would be no question they are OK. What you've found is just old stock of aftermarket parts. I would be very certain they contain asbestos, if that concerns you. I'm with Julie, I can't think of any steel drums ever used for brakes, but maybe in '30 they did? Are you sure the comments on wovens aren't about the band-type transmissions used on old Fords?
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree
MSD dizzy, 2110 Holley, Red's Headers
  #4 (permalink)
Old 07-03-2009, 11:30 AM
Posting Princess
1951 Ford F-100
In thinking about this a little, I think that steel brake "drums" were/are used on non automotive pieces of heavy equipment that are usually also aided by (and incorporated into) heavy flywheels - like concrete pulverizers or large generators. And they would b eused in lieu of cast to prevent any wear and strength (being very expensive to replace) But I would think they are much too hard for automotive use - cast is pretty soft.
In this case, like Ross said, if these are designated for automotive use, you are probably ok. I doubt very seriously your 1930 AA has steel drums.
__________________
Best wishes
Julie!
  #5 (permalink)
Old 07-03-2009, 11:26 PM
Quote:
You are absolutely correct about them not being NOS. I stand corrected. They are actually from Montgomery Wards. It must be OK because the box says "supreme quality" right on it. Can't get any guarantee better than that. I was able to get four sets, enough to do two trucks front and rear, for $50. That sure beats paying the suppliers $300 for linnings to do one truck. My drums are definately cast iron. I have heard of earlier brake drums being stamped steel although I have never seen one.
John
NNY
  #6 (permalink)
Old 07-05-2009, 06:29 PM
Did some more research. The brake linnings are 'Thermoid' linnings meaning that they are pressure molded with hard rubber. The Thermoid type linnings were used through the 50's as far as I can tell. They shoud work out great without any problems.
John
NNY
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
