short term project
short term project
I started to work on my newly purchased 1995 4x4.the alt was siezed from sitting and so was the air pump,so the air pump and all related garbage will be going in the scrap bin.and the alt will be here tomorrow from parts for trucks,much cheaper then in town.I also got the axle code from the door 18 3:08.not exactly ideal.and the 95 I'm driving now has 3:55's in it.I think I'll be pulling the cover on the 3:55's and if it all looks good I will swap the front and rear ends into the truck I'm going to keep.I only plan on running 31's on it but the little extra gear will help make up for the 300.
Received 1,384 Likes
on
on
scare me is right,there are two different ones,one is around 200,and the other is around 300 so my guy tells me,and I haved tried every scrap yard around and they have them,and will sell them,along with the complete engine haha.I friend gave me one this morning that has a few seedy looking spots.I have a guy here that does all our reefer repairs and he said he could silver solder it and I would have no troubles with it.so thats the new plan.I just blasted the loose flake of it and he is going to fix it up for me.easy fix.
on
I got the new rail in and no leaks,now I just have to see whats causing the clutch pedle to stay on the floor,its holding the clutch engaged so I'm guessing either a stuck slave,or with any luck the master is seized which would save me from pulling the trans.I'll try and find that answer today.
on
on
I had it running long enough for it to get warm and the two steel coolant pipes up front are leaking,the one from the thermostate houseing and the one from the water pump,I have another good pump,and I'll have to call ford and see if I can get a thermostate housing to replace the pipe.the worst of something sitting around.
on
well I'm going to go over this old thing from one end to the other,the old truck I'm driving now works good,so I'm not in any huge rush to get it done,if I go any distance I take the wifies car anyways.I have all the srvice records and such for the 6 cylender one,and it was undercoated and is in excellant shape underneith,so I figure I'll get the mechanical bugs all sorted out in the next month or so,and then go at the body.I called ford here and I can still get a ford box side for it,so I think the passenger side will be replaced and the drivers just has a small spot above the wheel so a small patch will do there.make a good job of the old girl so it lasts a couple years,and then I'll be heading for the southern states to find a 96 or so F350 4x4 crew.something to drag a trailer around with.
