Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 03:27 PM
jarod17's Avatar
jarod17 jarod17 is offline
Nevada CL
jarod17 is gaining momentum as a positive member of FTE.
460 differences
As I understand it when Ford went to the Fuel Injected 460 they changed the intake and the heads. I have a question on this,
Did they change the exhaust manifold mounting as well?
Here is my idea. I allready have a FI 460. If possible I want to put early style heads on my motor with a new intake. I allready have a set of headers on my motor so would prefer not to have to purchase a new set.
As far as the fuel injection goes I can have the intake modified to install the injectors and I allready have plans drawn up for the throttle body mounting. The biggest unknown right now is the heads. Will the old style heads mount to the new style block?
__________________
Jeff-Nevada Chapter Leader
Tell me I can't do it or it can't be done I will go out of my way to prove myself right.
People who say it can not be done, should not interrupt those who are doing it. Tom Monson
1996 F-250 4X4 460, 3.55, e40d
1985 D-350 Eventually going to have a Turbo Cummins
1971 F-250 Eventually going to have a 7.3 turbo Powerstroke out of a '99 or newer F-250
  #2 (permalink)
Old 06-30-2009, 05:46 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is starting off with a positive reputation.
the blocks are the same so yes the older heads will bolt to the newer block. you may want to check piston to valve clearance just to make sure that no problems there.
not sure on the headers, guess the only way to make sure is bolt them up to the older heads and check for any mis alignment.
rgds
Mike
Tags
460 , ford , fuel , injected , put , v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
