Gas vs PSD
#7501
Now I have to disagree w/ you. The PSD has the advantage. Its advantage is in the weight and in the tq and where the tq is made. There is no reason in the world to compare the v10 and PSD performace wise. This is a clear test of the 2 engines. Cause in this what if question we can deam that both trucks hook up to ground w/ good traction we can expext the PSD to pull the v10 for the shear TQ numbers and a meer 2,200 rpms. When you gun your v10 to get to your power band your doing se
veral things to your truck that robs power. The main thing is your flexing the frame which chances the traction bite. I don't have to twist my truck in a not to render 500+ ftlbtq. I've pulled a few cocky v10 and never break a sweat. I've notice in this thread and others like it that the v10 challengers just talk about pulling a 10k trailer a certain distancve the fgastest. I would just shake your hand and sit on my tailgate. That's just a race and my PSD is'nt fast at all. Let's talk about this, I have a 38' gooseneck trailer that I pull 18000-20000 lbs of hay on w/ my PSD. Nbow let's talk about who will out pull who on what day. Read my post or come out to the farm. I abuse my fords. I work the crap of them.the v10 and PSD where built to do 2 different things. Let's not confuse them as being on the same playing ground. Brang your stock v10 and I bet real early in the day you will either. Refuse to hook up to the task or quit.
As for hooking up to your trailer and pulling, I have no problem believing the powertrain could handle it, it's the rest of the truck. Those kind of loads really require a dually, or at very least a F350. With a 20,000 lb gooseneck, you're looking at over a 4,000 tongue weight, my payload was less than 3,000 lbs, I would destroy my springs after just a few tows, regardless if I had a PSD or V10. Sorry, that is just not work cut out for a F250.
And sorry, I have to disagree with the statement that the V10 is going to flex the frame more than a PSD. That just flat is not true. Torque twists the frame, not horsepower. Which engine has more low end torque? If anything, that is an advantage to the V10, but honestly neither engine is going to flex the frame of a super duty.
However, if you still think the V10 can't do it, try explaining why it is now found in the F750? I bet that can out tow your PSD...
#7502
performace
expext
deam
distancve
fgastest
is'nt
Nbow
Brang
Doesn't really matter to me, but whatever.
#7504
Me? Say no to hitching up to something or quiting?
You don't even want to know the stuff my trucks have to live with.
I'll pull loaded class 8 trucks around for a day if you want.
#7506
Diesel, FTW!!
#7507
#7508
#7509
#7511
No thanks, had 3 of them already. I also experienced the spring degradation on 1 of them. I could get in the back of it and jump and almost hit the bump stops with an empty bed... I only weigh 170 lbs.
It was funny though, I noticed the truck was squatting more with loads of gravel then when I bought it new. I took it to Ford and they said they couldn't find a problem. So I put 1500 lbs of gravel in it, drove it for a week untill it road on the bump stops, took it in and showed them, then they replaced the springs. It was rated to have a payload of 2080lbs, so I didn't overload it either.
#7512
I'm still trying to figure out what "hetro" means....The only thing I can think she was trying to say was "Hetero", which is short for Heterosexual....In a comment immediately after correcting someone else for spelling errors... I'm joking, but hey, there are many people who adopt the holier-than-thou approach around here and throw rocks in a glass house.
Diesel, FTW!!
Diesel, FTW!!
#7514
#7515
I understood both of the posts...(Hers and His) I was just pointing out it's not nice to point out one's spelling errors, then make one yourself on the very next post.
