does the smoke smell like burning wire insulation??? If it does your Glowplug/injector harness may be burning up...
That happened to mine not long ago. If it starts running rough or only on 4 cylinders that could be the problem
Sounds like blowby to me. Remove the oil cap with the engine running, turn cap upside down and put it back. If it gets blown off, you have excessive blowby.
X2 what he said. You could clean the doghouse for the CCV in the drivers valve cover, but its uncommon that it cloges (spell?), and pretty sure you are going to need new set of o-ring for it (they will be swallowed (spell againg?), so be prepared.
thanks, ya its blowby,340,000 mi.on er, i will see if she can make 500,000 mi, still runs strong, dont use much oil and dont seem to have alot of smoke out the tail pipe. im going to take it on a 800 mi. trip through the cascade and blue mountains of Oregon next week with the camper on and towing a big load behind, i will see if she can out do my old 86 6.9 that has made the trip many times, thanks,
