Oil leak from Fuel Pump????
I have a really bad oil leak come from my fuel pump. According to the manul it is comeing from the rocker arm pin. Does anybody know if there is a fix for this? Sorry for the bad pic i'll get a close up tonight.
http://i202.photobucket.com/albums/a...3-9-090032.jpg
<a href="http://s202.photobucket.com/albums/aa267/Ratkiller007/?action=view¤t=3-9-090032.jpg" target="_blank"><img src="http://i202.photobucket.com/albums/aa267/Ratkiller007/3-9-090032.jpg" border="0" alt="leak"></a>
For oil to be coming out by the fuel pump arm pin it would have to be extremely worn, it is more likely cause by excessive crankcase pressure, a build up of oil vapor, which has to vent somewhere. New engines use a PCV valve and vacuum off the engine to suck these fumes away and burn them, some older engines had a downdraft tube that got rid of the vapor. Either your engine is not venting correctly or something (that you do not want to know about) is causing pressure inside the oil pan.
But......."being wrong sure keeps me humble"
It's only leaking from that pin hole, not the gasket. I will have to check the base of the distributor tonight. I first noticed it after I replaced the valve cover gasket and reseated the breather (it never sealed correctly). So I think Old F1 is on to something. Could I have sealed things to well for this old engine? And Is this the down draft tube you are talking about? Because if it is I think it is clogged. I put my finger up there and felt some sort of waxy blockage.
hmmm i think i 'member that one julie . them old sixes can be quite an ordeal as they're not super popular and not a whole lot of 'em left , to get anything for . sounds like it's time for the easy way which i took with my flatty . an electric pump ! oh yeah and a regulator as the old carbs dont like the kinda pressure the pumps put out . don't ask how i know or found out ............................
Well hopefully I ordered the right one. The distributer said it is for a 54 f100 223 and in the picture it looks the same. I'll have to keep my fingers crossed.
Last night I took off the downdraft pipe and cleaned it out. There was tons of what looked like crystalized oil or maybe bits of road tar. It was nasty what ever it was. But no oil leak from the bottom of the distributor,
