Need some help with my power windows
I put a new stereo in my truck the other day and put new speakers in the front door and my window on the passenger side would not work. I was trying to figure out what was wrong with it today and checking plugs and seeing if I had power to the motor and switch. I have power to the motor and switch and all I can get it to do is go down but not up. The window will only go down with the passenger side switch and not the drivers side. I checked fuses and the relay and can't figure out what is wrong but now I need to get my window rolled back up. I have a 99 f-250 crew cab. Any help would be appreciated.
Thanks
Thanks
Ford really likes the 5 wire reverse polarity switches. The are a pain to work with half of the time though, but the good side is, if one wire is cut, it doesn't work at all. Moving in only one direction means the switches output is power and ground for the direction it works. And either no ground or no power in the opposite direction.
Try a switch from the rear doors, I suspect you have a bad contact inside it.
