superdutys in the sand
ok guys i live near the delaware beaches and was thinking about getting a surf tag for my truck.I have a diesel 350 and am looking for tips for going out on the beach. What should i bring with me out there should i air down i have 10 inch wide wheels on the truck. If anyone lives near there would b great to here about going out there..
Wow onboard air? That is freakin awesome. I first heard about them with the old hummers, but never thought about doing it myself? How hard was it? Did you DIY?
As far as the sand goes, I have been driving on it for years and today I got stuck with 38" 15.5 mickey thompsons. I couldn't engage the 4wd. I just bought the truck too.
I would recomend airing down for sure. 20 psi was always recomended to me too. Air down real low if you get into problems and dig her out.
I was lookign for surf tags to. n2dawater, epic, swell. Hope that helps.
Air down, bring a shovel and a tow strap. SD's as big and bad as they are...are not great off roaders without pretty drastic modification. Don't get me wrong, I LOVE my Super Duty, but it's not nearly the off-roader some of my other trucks have been. They are just too heavy in a lot of cases, especially for sand. I'm sure 100 people will follow this up and tell me how freaking awesome their SD is off-road, and I'm sure its' not bad, but in a stock configuration with the weak factory l/s, open front, massive weight,and stock tires... yeah not so much.
As long as you don't stop in the loose stuff, keep it moving, you'll be just fine. If you do get stuck, don't try and power your way out, or rock you way out. You'll just bury it to the axles. It's much easier to dig your way out when the truck isn't buried to the frame.
Come on guys. There is nothing cooler that driving right up on the beach to a sweet break and not having to lug 1000 lbs of the family's stuff over the dune to the beach. Drive up, park, drop your stuff off and play your radio on the beach. You just gotta remember to rinse the undercarriage when you get home.
Don't be scared to air down to 15psi. After you drive a bit you made need to check you air pressure again. This is due to the fact that the tires generate a lot of friction heat when running aired down and the air expands. I have found that after driving on the beach my tires will increase from 15psi up to 17-19psi. Trust me, on a sandy beach 2-3psi is a big deal.
For the record I drive the Cape Cod National Seashore which has some soft, soupy sand. A beach with firmer sand will not require as low of a tire pressure.
Ditto on the tow strap and shovel. I also advise you to carry a 5-ton bottle jack and a 12''X12'' piece of 3/4'' plywood to put under the jack. There's nothing worse than trying to change a flat on the beach and watching the factory jack sink into the sand as you try and raise your truck.
there two places here on long island that i go beach camping. shinnecock and shagwon(montauk). they both have dumpouts and air stations. i could be wrong but i think the on board air system that was talked about is just a compresser wired and mounted on the truck. the hummer system is involved it can air up or down while driving. the key to driving on the sand is don't be afraid to air down. my old tires 35"x12.5"x16.5" i had as high as 40lbs. and as low as 15lbs. definitly pack a bottle jack some wood planks a tow strap and a shovel.
