EAB head installation?
Old 06-16-2009, 09:15 PM
familyman65's Avatar
familyman65
familyman65 is offline
All you flathead gurus, I need to know if there is anything special to do when installing heads. I had to pull the heads and intake to clean some stuck valves. I know the tightening sequence, and to put a sealer on the head bolts, other than that I don't know. I have metal gaskets from the late 60's . It's an 8ba block, eab heads, and domed pistons 90 over. Any info would be greatly appreciated. Thanks, Kent.
Old 06-16-2009, 11:12 PM
Snowking's Avatar
Snowking
Snowking is offline
I believe you got the bases covered except for machine work. At least thats the way i always installed heads.
Old 06-17-2009, 09:00 AM
familyman65
Ok, I guess I made it sound like I know more than I do. The last time I worked on a flathead was 35 years ago. This engine to be exact. I can't remember much of the process. I was only 17. I don't know what to put on the bolts only that in one of these threads someone said they needed sealed. So what is something good to use? Can I use it on the head gaskets also? Thanks, Kent
Old 06-17-2009, 10:53 PM
Snowking's Avatar
Snowking
Snowking is offline
Thread Sealant. The head bolts are apart of your water jacket so you seal the threads to prevent coolant loss. Not a mandatory step but a smart one.
Old 07-01-2009, 03:15 AM
55 f350's Avatar
55 f350
55 f350 is offline
yep lots of it ! i didna put any on mine and am beginning to wonder if it wasnt the cause of mine { head gaskets } to start leaking . dain newb's we don't know squat .........
Old 07-02-2009, 06:58 PM
familyman65
What would be a good brand of thread sealant? Permatex # 2, or ???. Once I get the carb rebuilt I will be installing the heads . Hopefully within a week or so. Thanks
arrowheadfred
34
10-29-2015 04:36 PM
Jack1948
07-07-2015 12:45 PM
1950FordF1
WTB - Parts & other
12-26-2014 12:52 PM
r_reed
16
10-02-2012 06:28 PM
rrm99a
1947 and Older Ford Trucks
01-13-2005 08:16 PM
Quick Reply: EAB head installation?
