Nominations/Volunteers for NM chapter leader!
on
Randy has requested that a new chapter leader be found for the NM chapter. His time is very limited now to be able to serve the chapter as the job requires.
SOOOOOOOO, nominations or volunteers for the chapter leader position are hereby open. This thread will remain open for 30 days. At the end of that period, an election will be held if necessary. If there are NO nominations or volunteers then the chapter will be put on "Auto Approve" for new member join requests.
Chapter Leader guidelines can be found here,,, https://www.ford-trucks.com/forums/7...-1-2008-a.html
Chapter guidelines can be found here,,, https://www.ford-trucks.com/forums/7...-1-2008-a.html
If anyone should have any questions about the position, you can contact Rich, 99trigger3_0 or George, glruff who are the Regional Chapters Moderators.
If you nominate a member, make sure that member will accept the nomination.
If it involves the deep end of the pool, a brick and some guy screaming at you about your swim buddy... I'm not down for that again.
