Pics/plans fro a better wash system?
Old 05-29-2009, 11:22 AM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
We are working on processing about 65 gals a wk. Attached is a pic of the Magnesol filtering setup. It works, but there's got to be a better way . The "tower" has 3 4" diameter bags inside each other. 10-5-1 micron. The pump in the barrel is set about 4 inches off the bottom of the barrell, so most of the bio pulled is very clear already. It gravity feeds through the filters, then siphons into 6 gallon containers.
Heard some of you use diaphram pumps to pull bio through the filters.
Old 05-29-2009, 10:15 PM
Rushmore X's Avatar
Rushmore X
How about for
How about for a better wash system. Heat must have got to my brain...
