Massive Oil Consumption .. Please HELP!
I've had this problem for just under a year. I've been watching my oil level closely. My truck will all of a sudden use 4 to 8 qts of oil in 100 miles. I fill it back up and it goes a while (sometimes weeks) without using a drop. Then it sucks up quarts again. A few days ago it started hard, blew lots of blue smoke, warmed up and seemed normal. I checked the the oil and it was at the normal range. Then while driving down the freeway I noticed the cloud of blue smoke behind me. I was able to get the truck home and the level was right at the bottom of the stick.
Since then, I have pulled the turbo outlet air tubes and they were only slightly damp with oil (no pooling). While I had the tubes off, I checked the turbo. No end play and virtually no side to side play. The CCV (on the drivers side with 2 screws) was clean. The truck still seemed to run strong, but 5 qts in 15 miles is crazy! So right now it's dead in the driveway. 2002 7.3L 125K miles
no oil in coolant ... exhaust is sooty black, not wet.
I've got the turbo tubes off the truck right now. Last time I ran it (back home after heavy blue smoke running down the freeway), it was rough and HEAVY smell of oil at idle.
Is there anything I can check reguarding the turbo before I pull the valve covers? Or can someone tell me how,why and where the oil could be burning involving the turbo? I'm new at this so I need help understanding the turbo oiling.
Thanks for the replys .. I really need to get my truck on the road again soon!
I'm beginning to think it's injector related. Turbo outlet was dry and exhaust was just sooty. I just picked up 8 injector seal kits. Anything I shouild look for as far as inspecting the injectors once I have them out? At 130K miles is there a rebuild kit for injectors that I should think about?
You could take the valve covers off and start the truck up. There is a discharge point for each injector. Watch the injectors at idle to see which one(s) aren't spitting oil like the rest of them. With mileage that low, I wouldn't worry about having the injectors rebuilt.
As for the injectors, the most likely suspect would be a bad o-ring. There's 3 o-rings on each injector. Do you know how to pull and stick the injector back in, or do you need some pointers on that? You'll want to make sure you get the oil out of the cylinders after you pull them.
