New Jersey Chapter Join Chapter Leader: sddesigns
NJ state Inspection help
Old 05-26-2009, 11:14 PM
BlueOvalPower's Avatar
BlueOvalPower
BlueOvalPower is offline
so i get a pretty clean 92 F-150 that sat for a year... i get it running ok, i tag it and my wife decides shes gonna get it inspected while im at work, Yea well if only i knew... It FAILED it wasnt ready... SO now idk what to do ... i dont have the $ get the things it needs fixed.. Anyone have any ideas? id really appreciate it
Old 05-27-2009, 05:53 AM
sddesigns's Avatar
sddesigns
sddesigns is offline
Find a friendly service station that does NJ Inspections and hope for the best.
What part of the state are you from?
Old 05-27-2009, 11:48 AM
BlueOvalPower
im from Southern nj Gloucester County
Old 05-27-2009, 12:24 PM
sddesigns's Avatar
sddesigns
Maybe someone down near you can jump in here to help you out with a local inspection garage.
Old 05-27-2009, 08:08 PM
plowin4u's Avatar
plowin4u
plowin4u is offline
What items did they fail the truck on? Emissions, brakes, suspension? You have 45 days to correct problems, if not ,you can bring it back and get additional 45 days, you can still use truck.
Old 05-27-2009, 11:54 PM
BlueOvalPower
i failed for Emissions, Steering lash, rear brakes outta adjustment, Front gas cap, Headlight, ..... i fixed the Headlight, gas cap,
Old 05-28-2009, 02:01 PM
NJF350SD's Avatar
NJF350SD
NJF350SD is offline
"Steering Lash". WOW. The last time I had steering lash checked was on my '87 3/4 ton when I had stability testing done in Lodi for the 7" of lift I had installed...
Old 05-28-2009, 07:33 PM
plowin4u's Avatar
plowin4u
plowin4u is offline
Steering lash is probably excessive play,maybe bad tie-rods or steering arm, emissions can be several different items, on your printout, does it show high hc or co readings?
