DANA 60 codes - What/when was it born under?
Old 05-01-2009, 07:38 PM
BarnieTrk's Avatar
BarnieTrk
BarnieTrk is offline
Ok Fellas,
Who has their DANA 60 ID book handy?
(I went to DANA's web site, it only goes back to '78. I searched for a chart or such on FTE's transmission/differential/transcase forum, lots of info on FRONT DANA 60s, but didn't find any answers for this....so here I am)
I've got a full-floating DANA 60 under my '65 F250, however, based on some notes from the PO, the rearend MAY have come from a '67 F250/F350.
Here are the codes I took off it today:
-- The casting has the requisite ' 60 ' cast in to the lower RH corner of the case.
-- Cast into the upper RH corner of the case is: ' C-30255 '.
-- I believe I located the Born on Material (BOM) stamping on the RH axle tube. It reads: ' 5 12 7C1 '.
-- Lastly, is the tag at a rear cover bolt (which I'm not too confident to believe, for some odd reason) which reads, ' C7TA-BV 602311-1 4.10 '.
Can anyone help decipher what all these numbers tell us?
At least can we determine what year/model this rearend came out?
Thanks in Advance, Guys!
BarnieTrk
Old 05-02-2009, 08:18 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C7TA-BV = 1967 F250 Dana 60 / 4.10-1 / non Limited Slip / Ring gear has 29 splines (1965: 10 splines).
5 12 7C1 / Assembled May 12, 1967 / C1 is the code for the assembly plant.
The fact that the rear axle ID tag is still there...is somewhat amazing, as most are missing by now.
There are two possible reasons why:
1) The axle has never been apart.
2) Whoever worked on it...remembered to put the tag back on.
All 1961/67 F350's used Dana 70's. 1953/67 F350's have 6 lug wheels on a 7.25" bolt circle.
Old 05-02-2009, 08:25 AM
BarnieTrk's Avatar
BarnieTrk
Hey Bill,
Thanks for coming to my rescue!
So it appears that the tab may be correct since it sorta matches the assembly date...... Cool.
Now I know what I've got & get the parts accordingly.
Have a GREAT day!
BarnieTrk
P.S.
Do you know what all, if anything, was different between the DANA 60s with the various GVW packages, or was it just different brakes and different "leaf spring packages"? This DANA 60 has the 12" x 2.5" brake shoes.......
Old 05-02-2009, 08:40 AM
NumberDummy
I added more info inre to F350's.
The GVW had nothing to do with the rear axle, just the springs, possibly the shocks would be different.
I wonder when the rear axle was changed if the rear brakes were also changed.
1953/65 F250's had 12 1/8" x 2" brakes front/rear.
1966 was the first year 12" x 2 1/2" front/rear brakes were also available.
As original, the front/rear brakes would be the same size.
But that may not be the case now...if the brakes are from 1967 and are 12 x 2 1/2.
Old 05-02-2009, 09:04 AM
BarnieTrk's Avatar
BarnieTrk
So in other words, it appears as though when the rear axle was replaced with a '67 axle, they left the '67 (12" x 2 1/2") brakes on it?
(If that's the case, that's a good thing as it give me more brake shoe surface area than the '65 brakes would have had.... )
The front axle brakes ARE 12 1/8" x 2"....
Thanks again for your help, Bill !
BarnieTrk
Old 05-02-2009, 01:31 PM
NumberDummy
It could have 12 x 2 1/2" brakes, it could have 12 1/8" x 2. The point was that after 1965, both sized were available.
BarnieTrk
The thing with the 12 x 2 1/2" brakes (if you now have them) is...they're at the rear.
60% of the braking is done with the front brakes.
Old 05-02-2009, 01:49 PM
BarnieTrk's Avatar
BarnieTrk
Agreed. If I could wiggle my nose and make the larger brakes on the front, rather than the back, it would be a better deal.
I just ordered new shoes; front & back. DANG! They don't give those away either!
The shoe pads are riveted onto the steel instead of bonded; I'd prefer bonded since I'd likely get more miles out of them.
But, "Ya gotta play with the cards you're dealt."
BarnieTrk
Old 05-02-2009, 02:25 PM
NumberDummy
BarnieTrk
Back then, Ford only sold riveted brake shoes or lining, you wanna know why?
Because...when the shoes wore down, the rivets would cut grooves into the brake drums!
Ford like all the other automakers back then...and today, is really in the partsbiz.
Over 75% of the profits come from parts sales, not vehicle sales.
The markup on what Ford paid for the parts from suppliers as opposed to what the dealers paid Ford for parts..was/is close to 80 PER CENT!
If parts don't wear out, no profits for automakers.
Old 05-05-2009, 11:26 AM
BarnieTrk's Avatar
BarnieTrk
Say Bill,
You mentioned that the ring gear has 29 splines
You were referring to the pinion gear-to-yoke spline count, correct?
BarnieTrk
Old 05-05-2009, 12:28 PM
NumberDummy
Say Bill,
BarnieTrk
-- Correct --
Old 06-07-2010, 02:06 AM
hundredproof87's Avatar
hundredproof87
hundredproof87 is offline
havin issues with the nubers nd the answers ppl give
i have a 76 f250 highboy. supposed 2 have dana 60s front 4:11 rear 4:10. rear axel came outta a bronco hadta move spring purches in 3.5 inches( got behind seat tank frame 34 inchs) no id tag. its got 60 stamped on it nd c-30255 stamed also. i wanna know gear ratio. spedo doesnt work. found a calculator on line to determine speed but need to no gears 4 every thing. np2o5 1.96:1 t case. 33x12.50x16.5 tires(need a set , bigger,if ne one has ne) that measue 31. nd trans tag nums d3ta7003dc fl112 3 17 76 435.if u no ne thing bout the date codes i dont ad up... d means 70. 3 means 3. t means truck. a means axle. but the date says 76. wtf is goin on. i know the truck will only do 78 in 3rd but the slowest speed i cld find on calck says 95 nd its jst not gonna happen in this truck evan wit the c5ae 289 hi po wit 600 cfm edelbrock 4v... if ne of this makes sence cld u help me out...
Old 06-07-2010, 02:50 AM
NumberDummy
Welcome to FTE
Dana 60's from 1972: The 2" x 1/2" Dana ID tag is bolted onto the housing using two bolts...just to the left (rear axle), to the right (front axle) of the inspection cover.
The code is composed of 7 or 8 numbers, like these examples: 603010-1 or 603010-11.
The Ford ID tag was located under one of the bolts that retains the inspection cover to the housing. Many of these are now missing.
Old 06-20-2010, 07:17 AM
yargnitram's Avatar
yargnitram
yargnitram is offline
what is the size of the rear shoes in a 1965 f250 v8 camper special, any ideas of hand/park brakes cables part numbers
Old 06-20-2010, 07:42 AM
BarnieTrk's Avatar
BarnieTrk
A '65 F250 Camper Special was typically originally equipped with a DANA 60 rearend (your door tag information should confirm if it was or not) and all '65 F250s were fitted with brake shoes that measured 12 1/8" x 2".
What specifically emergency brake part numbers are you searching for?
Do you need ALL of the emergency brake hardware & cable part numbers - from the under the dash handle all the way to the rear drums or just some of the parts?
BarnieTrk
Old 06-20-2010, 02:33 PM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
Barnie...if you wanna put the full 12 X2 1/2" brake setup on yours...let me know...Ive got the full front end from a 69 3/4 ton...drum to drum...needs a new home...been taking up alot of room out here...
As for the E brake parts...ask away....Ive got a few E brake parts...
- cs65
Quick Reply: DANA 60 codes - What/when was it born under?
