300 rpm jump up in idle at operating temp?
What would make the idle go up @ 300 rpm's once engine is up to operating temp. It's an 86 F150 w/EFI ,dual tanks, 302 with110,000 miles. I have replaced temp sensor and the idle control motor, canister fuel filter on the frame and it still jumps up after it's warmed up also it won't start now with out a couple of shots of starter fluid? All worked well when I parked it mid winter . I'm open to any thoughts or suggestion. K.C.
Is the throttle body closing completely when you let off the accelerator? Maybe it need to be cleaned..
Check the choke too
Could be the choke plate is not opening all the way. If its an electric choke, unplug it after its warmed up and see if it doesn't go back down. Check for blocked linkages, I had a vacc line runing through mine and caused a similar affect.
Could also be too much vacc at distributor? Also check the timing for the no start.
seventyseven250
Modular V8 (4.6L, 5.4L)
01-10-2010 09:44 PM
kcyuba
04-15-2009 08:30 PM
Scott Fraser
36
11-15-2004 07:06 PM
