Up-pipe leak repair
Up-pipe leak repair
I have leaks at the donut gaskets on the up-pipes. Talked to Clay yesterday. I can't spend the money on the bellowed up-pipes. I know that would be the way to go, but I can't.
I have read somewhere about using Chevy donuts. About using never-seize in the donuts and tightening the ends slowly while twisting the pipes slowly to make sure they seat properly.
Anyone tired either or both, any suggestions? Get the donuts from IH, Ford?
Thanks in advance.
Thanks in advance.
Here is the link for the brass ones: Beans Diesel Performance - 94-03 Power Stroke Brass Up pipe Donut gaskets (Powered by CubeCart)
I also have to change the up-pipes but I think I really want to do it with the turbo in place due to the fact that I have a Banks Brake installed as well and it is a real pain getting it all out of there. I was told that you can take the inner fender liners out and gain access. Has anyone done it that way and was it successful. Also can someone post a link the the bellowed up pipes as I have never heard of them. Thanks.
Some reading for you..............https://www.ford-trucks.com/forums/8...for-cheap.html
Contact Riffraff Performance in that thread and he will set you up. I got mine from him.
I too have a Banks brake on my truck, I didn't install it though. It made it a little more tough to take out, but not much. The exhaust band clamp is just a little further down ( I guess you already know this though) and we had to turn the brake on to open the actuator to slide the clamp off. Other than that, it just makes the turbo heavier.
