converting 6 volt to 12 volt
#31
#32
Wow this one kind of popped up after being dormant for awhile - and with lots of questions.
First wiper switches. If you have a 6 volt wiper motor and switch, you can keep that and use it with a 12 volt conversion and use a vol-ta-drop. But you can't mix motch a 12 volt motor with a 6 volt switch, etc. The switch has to match the motor, and normally has to be made for that particular motor for the parking functions to work correctly. There are, of course, exceptions, but for now that is the best way to go.
As far as an alternator is concerned, there are lots of non GM one wire options. The later Ford paroducts used one wire and I found a great company called "Tuff Stuff" that actually built my chrome one wire alternator because I had an interference problem where it was mounted. It was about $125 a couple years ago as I recall. Here is the link to the site:
http://www.tuffstuffperformance.com/...asp?partid=140
Also, LMC is starting to carry generator look alternators that I believe are one wire but not 100% positive. You might check them out as well.
Lastly, I don't have any data on the reducer you mentioned. I use the Vol-ta-drop on my truck to power one las 6 volt accessory - my Magic Air Heater - because 12 volt motors are not available and it's an "off" size. I also used a vol-ta-drop on my 55 to use the 6 volt overdrive transmission and have always found them to be reliable and do the job. They've been around a long time and have a good reliable reputation. So, I haven't looked at other products - I tend to stick with the things I know are dependable and safe.
I also use the individual gauge reducers. I got some feedback on the reducer that is the single unit that reduces all the gauges. Seems it gets hot enough to melt wire insulation that might be touching it. I guess you could use a vol-ta-drop there too but that's a lot of bulk just for gauges.
#33
I'll add to this one a little bit. There are higher amp rated electronic reducers available for the wiper and heater motors. Mid-Fifty has them for $63. These electronic jobbies are awesome. Mine hasn't been getting hot, like Julie mentioned, but I only have one installed, and only on the gas gauge. I will be adding the bigger electronic one for my original 6 volt wipers, though. I'm going to replace my heater with a 12 volt motor, only becasue the switch is dead, and if I'm gonna change the switch, I'm gonna change the motor. A lot of places talk bad about the porcelain volta-a-drops, but I'm with Julie. They have been around for several decades, and I've never seen a rig have a problem with using them.
#34
http://chris66dad.tripod.com/id29.html
if i did this right ,this is the link to the IVR.please check it out and see what you think.some feed back would be great.
#35
#36
retro.i dont know,that why i was trying to get some one to read this link.he did say he needed to make a couple more of these,so i think you would need one for each gauge.but i think you would have to use a heavier version for the wipers.i just happen to come across this and thought it was pretty cool....if it works like this guy says it does.
i dont suggest for anyone to just go and make some of these and put them in your trucks before we get some feed back on them.i think i will make one and try it ...if i can.
sometimes new is good.....sometimes new is VERY bad.
#42
#43
#45
I used Texas Instruments' PT6654G and adjusted the output from 9V DC to 6.6V DC. I'm an engineer in my day job.
See: Mouser @ PT6654G Texas Instruments | Mouser
Data sheet is here:
http://www.ti.com/lit/ds/slts038b/slts038b.pdf
Didn't figure out how to put a link, sorry. What can I say, I'm a hardware guy.
Data sheet is here:
