sugar in the gas tank.
"I got a friend with a 00 lightning and some punk put a pound or more sugar in his gas tank."
Probably some retard who had his *** handed to him while racing the Lightning. Some people don't deal with defeat very well.
Red 2001 Lightning with stock drivetrain
13.61 @ 102 MPH spinning factory F1s.
[B]RUNVS?
[B]RUNVS?
I was under the impression that since sugar won't disolve in gas that it would just plug/clog up the filter, thereby restricting fuel flow. That sounds like what would allow him to only get up to 20 mph. Could a person remove the plugged filter, while opening the fuel line into a empty gas can or other container to drain the sugar, or would this require dropping the tank?
I think dropping thank would be the best bet since most have a sock looing filter inside the tank. If you clog up the sock filter it just sucks closed especialy if the pump is in the tank.
One more sugestion, locking Gas cap. When your fast your bound to **** someone off.
